Public KeyDB Disc Submissions
keydb_helper
#1 Post by keydb_helper » Thu Jun 26, 2025 1:40 am
Hi everyone, I've created this thread to act as a central location for posting disc dump file submissions for the public keydb. Thank you to the moderation team for allowing this thread to be trialed.
Please include the disc ID in your submission template. The disc ID is the SHA-1 hash of the Unit_Key_RO.inf file in your discs AACS folder. Many tools can calculate this hash, please google the instructions for your specific platform.
Submission template:
[b]Disc type:[/b]
[b]Disc ID:[/b]
[b]Disc dump filename:[/b]
[b]Drive:[/b]
[b]Drive firmware:[/b]
[b]LibreDrive status:[/b]
[b]Did you sync the public keydb within the last 15 minutes?[/b]
[b]Have you verified that all submission links are accessible in incognito/private browsing?[/b]
[b]MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):[/b]
[b]Disc dump link:[/b]
Submission example:
Disc type: UHD
Disc ID: 0x3107C2E7A9E653308559C7ED8E261D9702F4C5F4
Disc dump filename: MKB20_v77_The_Sound_of_Music_BCE8
Drive: BW-16D1HT
Drive firmware: 3.10MK
LibreDrive status: Enabled
MKB_RO.inf link: <Link>
Disc dump link: <Link>
I hope this will lead to less issues caused by large file attachments and reduce confusion regarding the state of native title support in MakeMKV.
Please stop posting links which are either broken, unavailable or not publicly accessible. Before posting a link in this thread open up incognito mode and verify that your disc dump file can actually be downloaded.
What is the public keydb?
The public keydb (key database) is a community run initiative which provides a database of keys for decrypting Blu-ray discs. The public keydb is independent of MakeMKV but if configured properly MakeMKV can utilise the public keydb to decrypt discs which it does not yet natively support.
Emailing disc dump files to the MakeMKV team is still recommended to assist with native title support.
What is the benefit of providing disc dump files?
If you can provide a suitable disc dump file in this thread, it will be supported by the public keydb within 12 hours. Otherwise you may need to wait days or even weeks for MakeMKV to natively support your disc.
Link to instructions for configuring MakeMKV to utilise the public keydb
Link to the public keydb homepage
Link to SamuriHL's KeyDBTool for Windows
How can UHD discs be added to the public keydb?
Upload your disc dump file produced by one of the aforementioned drives to any file host and post the link in this thread.
Please do not directly attach disc dump files as this causes storage quota issues and a maintenance hassle for the forum administrators.
Partial disc dumps
UHD disc dump files are generally 3-8MB. If your disc dump is less than 1MB, you will need to manually include the MKB_RO.inf file when uploading your disc dump file. You can find this file within the AACS folder on your disc. The MKB_RO.inf file may be ~128MB so feel free to zip it before uploading it.
Do not just extract the ~56 byte MKB_RO.inf file from a partial disc dump file and upload it separately. This is not helpful. Instead, copy the MKB_RO.inf file from the AACS folder on your disc and upload it separately. If your MKB_RO.inf file is not several megabytes in size, it is probably not useful for UHD discs.
Please ensure that all file links are publicly accessible before posting in this thread.
Don't forget to try out the latest public keydb before posting to this thread. Remember, even if MakeMKV doesn't natively support your disc it may already be supported by the public keydb
Last edited by keydb_helper on Wed Jan 07, 2026 2:17 pm, edited 11 times in total.
KeyDB Download
#2 Post by SamuriHL » Thu Jun 26, 2025 2:26 pm
This is great! Bumping it up so it stays visible for people. Maybe it should be stickied.
#3 Post by Coopervid » Thu Jun 26, 2025 8:47 pm
SamuriHL wrote: Thu Jun 26, 2025 2:26 pm This is great! Bumping it up so it stays visible for people. Maybe it should be stickied.
I will ask Woodstock if he can do that.
keydb_helper
#4 Post by keydb_helper » Fri Jun 27, 2025 2:27 am
Coopervid wrote: Thu Jun 26, 2025 8:47 pm
Thanks SamuriHL, Coopervid, and Woodstock for suggesting, arranging, and approving the stickying of this thread
KeyDB Download
garnuts
Sinners MKB20_v82_Sinners_5992.tgz (Steelbook USA)
#5 Post by garnuts » Thu Jul 03, 2025 8:53 pm
Here's the dump for the new Sinners Steelbook from the US
https://drive.google.com/file/d/11kVPTU ... sp=sharing
AACS/Unit_Key_RO.inf last date modified 6/4/25
keydb_helper
Re: Sinners MKB20_v82_Sinners_5992.tgz (Steelbook USA)
#6 Post by keydb_helper » Thu Jul 03, 2025 11:31 pm
garnuts wrote: Thu Jul 03, 2025 8:53 pm Hi,
Thanks garnuts, the 5992 variant of Sinners has been added to the public keydb.
KeyDB Download
reversion
#7 Post by reversion » Fri Jul 04, 2025 7:09 am
I’m submitting a key dump for a standard (non-UHD) Blu-ray and wasn’t sure if non-UHD titles are accepted here. Any advice would be appreciated.
MKB_v82_USG_20THBESTTOUR_LIVEBD_FCDA.tgz + MKB_RO.inf
https://drive.google.com/file/d/1eyUbPL ... sp=sharing
keydb_helper
#8 Post by keydb_helper » Fri Jul 04, 2025 12:29 pm
reversion wrote: Fri Jul 04, 2025 7:09 am Hi,
Thanks for the disc dump, it has been added to the public keydb.
I have no problem with standard AACS 1.0 titles being posted in this thread. But it is important to remember that you can currently generate the disc keys for AACS 1.0 titles by yourself. See SamuriHl's post here
KeyDB Download
youley
#9 Post by youley » Fri Jul 04, 2025 4:06 pm
keydb_helper
#10 Post by keydb_helper » Fri Jul 04, 2025 8:07 pm
youley wrote: Fri Jul 04, 2025 4:06 pm UK Superman 2 The Donner Cut UHD
Thanks for the disc dump file youley. The 3FF8 variant of Superman 2: The Donner Cut has been added to the public keydb.
KeyDB Download
carlosli
#11 Post by carlosli » Fri Jul 04, 2025 8:54 pm
Here is my dump, hope you can help to decrypt
https://drive.google.com/file/d/1uLbbkq ... sp=sharing
MrPenguin
#12 Post by MrPenguin » Fri Jul 04, 2025 10:47 pm
carlosli wrote: Fri Jul 04, 2025 8:54 pm Here is my dump, hope you can help to decrypt
Where is this dump file?
#13 Post by Woodstock » Fri Jul 04, 2025 10:47 pm
Files over 4MB won't go through... and a lot of the recent upload attempts were for very large files.
carlosli
#14 Post by carlosli » Sat Jul 05, 2025 6:01 am
MrPenguin wrote: Fri Jul 04, 2025 10:47 pm
mich52
#15 Post by mich52 » Sat Jul 05, 2025 10:28 am
