Dump for Bring it on 4k UHD (2000)
josh31p
Post by josh31p »
Dump for Bring it on 4k UHD (2000). I have also emailed earlier on.
tvanbuskirk
Re: Dump for Bring it on 4k UHD (2000)
Post by tvanbuskirk »
Also have an unrecognized copy of Bring It On. Sent in to svq@makemkv.com. Updated KEYDB file before trying to open disk. Dump attached for The Powers that KEYDB.
MrPenguin
Post by MrPenguin »
josh31p wrote:
Wed Jun 25, 2025 6:03 pm
Could you also provide the TGZ dump file here please, either as an attachment or via a download link? This would allow people to try to add your disk to the public KEYDB.cfg file too.
FWIW the KEYDB.cfg file already contains an entry for this disk:
0x4E800524C99B064A85C7DD4AF9C9D9EBCB1A6B31 = Bring_It_On (Bring It On) | D | 2025-04-04 | ...
which might be your disk. Try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV, to see if this allows you to decrypt your disk.
josh31p
Post by josh31p »
The link for the latest KEYDB.cfg doesnt appear to work for me, I get a 404 not found. Here is the link for the tgz file.
https://www.dropbox.com/scl/fi/2nu0yk87 ... yk47m&dl=0
Thanks again
josh31p
Post by josh31p »
I got the latest KEYDB file and it is working now. Thanks
