Dump Submitted: Crime Story 1993 [4K UHD by 88 Films, 2025]
sradford
Post by sradford »
Emailed dump file for MKB20_v82_CRIME_STORY_B3C2.tgz
MrPenguin
Re: Dump Submitted: Crime Story 1993 [4K UHD by 88 Films, 2025]
Post by MrPenguin »
sradford wrote:
Tue Jun 24, 2025 3:16 pm
Could you also provide this dump for the KEYDB.cfg file please, either as an attachment or via a download link?
sradford
Post by sradford »
Do you mean, download the KEYDB.cfg file and place it in my MakeMKV data folder, then restart MakeMKV and try to re-open the disk and then provide the tgz file again?
Thank you
MrPenguin
Post by MrPenguin »
sradford wrote:
Wed Jun 25, 2025 7:00 pm
The KEYDB.cfg file already contains an entry for this disk:
0x67729174FB9DD859EE5FD2B9E11BBF54420CFBC9 = 88FU045A (CRIME STORY) | D | 2025-03-19 | ...
This might match your disk, in which case installing the KEYDB.cfg file as you describe will allow MakeMKV to decrypt it. However, if it doesn't match then MakeMKV will generate a new TGZ dump file which is the same as your existing TGZ file. And providing that dump here would allow people to try to add your disk to KEYDB.cfg too.
sradford
Post by sradford »
Installing the keydb.cfg enables MakeMKV to decrypt my disk, and so I believe all is good (i.e. no need to provide a link to the dump file).
