Dumps Submitted: Armour of God II Operation Condor
Lostintime
Submitted dumps for both the the HK cut and the extended cut.
MKB20_v82_ARMOUR_OF_GOD_2_-_OPERATION_CONDOR_46A0.tgz
MKB20_v82_ARMOUR_OF_GOD_2_-_OPERATION_CONDOR_72F8.tgz
https://drive.google.com/file/d/1Fe5CSv ... drive_link
https://drive.google.com/file/d/17xRNXk ... drive_link
I am trying to attach the dumps but am getting a "Sorry, the board attachment quota has been reached." error when trying to attach them.
MrPenguin
Re: Dumps Submitted: Armour of God II Operation Condor
Maybe upload them to (say) Google Drive or OneDrive, and then provide some download links?Lostintime wrote: Mon Jun 23, 2025 7:57 pm MKB20_v82_ARMOUR_OF_GOD_2_-_OPERATION_CONDOR_46A0.tgz
Lostintime
Thank you. Linked in the OP.MrPenguin wrote: Mon Jun 23, 2025 8:05 pmMaybe upload them to (say) Google Drive or OneDrive, and then provide some download links?Lostintime wrote: Mon Jun 23, 2025 7:57 pm MKB20_v82_ARMOUR_OF_GOD_2_-_OPERATION_CONDOR_46A0.tgz
sradford
As per the FAQ, did you email the dump files to svq@makemkv.com ?
newmkv
Attached both dump file & error screen.
Also emailed to mkv already
MrPenguin
newmkv
sorry what is that .cfg? when i click that, looks like invalid one.MrPenguin wrote: Thu Jun 26, 2025 8:44 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?newmkv wrote: Thu Jun 26, 2025 8:13 pm Attached both dump file & error screen.
MrPenguin
Download the .zip file from that website and extract the KEYDB.cfg file inside it.newmkv wrote: Thu Jun 26, 2025 11:50 pm [sorry what is that .cfg? when i click that, looks like invalid one.
newmkv
clicking that link does not show anything. is it the right link please?
MrPenguin
The site only supports HTTP. Is your browser insisting on using HTTPS?newmkv wrote: Fri Jun 27, 2025 7:41 pm clicking that link does not show anything. is it the right link please?
newmkv
ah ok. Works now. Trying this. will keep you postednewmkv wrote: Fri Jun 27, 2025 7:41 pmclicking that link does not show anything. is it the right link please?
newmkv
Copied that to my local makemkv folder where it writes that zip file. Restarted makemkv and tried but same exact error as attached.MrPenguin wrote: Thu Jun 26, 2025 8:44 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?newmkv wrote: Thu Jun 26, 2025 8:13 pm Attached both dump file & error screen.
- Screenshot 2025-06-27 160306.jpg (68.4 KiB) Viewed 7254 times
- Screenshot 2025-06-27 160036.jpg (169.59 KiB) Viewed 7254 times
MrPenguin
You need to extract the KEYDB.cfg file from inside that ZIP, and then copy the KEYDB.cfg file into that directory.newmkv wrote: Fri Jun 27, 2025 8:03 pm Copied that to my local makemkv folder where it writes that zip file. Restarted makemkv and tried but same exact error as attached.
newmkv
You are genius. thanks a lot.MrPenguin wrote: Fri Jun 27, 2025 8:23 pmYou need to extract the KEYDB.cfg file from inside that ZIP, and then copy the KEYDB.cfg file into that directory.newmkv wrote: Fri Jun 27, 2025 8:03 pm Copied that to my local makemkv folder where it writes that zip file. Restarted makemkv and tried but same exact error as attached.
Followed this exactly & now able to rip it.
But very strange that when playing this ripped mkv in my usual 4k zidoo media player, audio is too low and i immediately played the actual disc which plays naturally loud/fine. Of course in makemkv selection, i enabled all ticks which i ve been doing for all other discs. any idea why it plays too low sound?
