Dump for Jaws: The Revenge (1987)
mattmak464
Post by mattmak464 »
Dump submission for Jaws: The Revenge (1987) D1F1
Filename: MKB20_v77_Jaws-_The_Revenge_D1F1.tgz
(147.41 KiB) Downloaded 49 times
MrPenguin
Re: Dump for Jaws: The Revenge (1987)
Post by MrPenguin »
mattmak464 wrote:
Mon Jun 23, 2025 11:33 pm
Thanks for the dump, but can you also provide the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV :(. (MKB_RO.inf files are actually very large, and so you would need to zip compress it. And probably upload it to somewhere like Google Drive or OneDrive and then provide a download link here.)
mattmak464
Link to the MKB_RO.inf from the disc.
https://drive.google.com/file/d/1HDapZW ... share_link
MrPenguin
Post by MrPenguin »
mattmak464 wrote:
Tue Jun 24, 2025 9:43 am
Thanks for providing this. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
