The fast and the furious 4K UHD Key not Present
Tried adding newest KEYDB.CFG to /home/user/.MakeMKV folder without luck
ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT'
Moviepack was bought from coolshop and it is fast and furious 9 movie collection. Other disks rip fine but not the first movie
MakeMKV dump file
https://drive.google.com/file/d/1fhMMD6 ... drive_link
MakeMKV dump file
Re: The fast and the furious 4K UHD Key not Present
It looks as if LibreDrive was not enabled for your UHD drive:
SDF v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO1P31I5206
001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E)
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:5'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your driveRe: The fast and the furious 4K UHD Key not Present
Weird since i have flashed my drive with libredrive enabled firmware and it rips other 4K movies
It doesn't look like you have flashed the drive with libredrive compatible firmware. Can you post your MakeMKV drive info / libredrive info sections.MrPenguin wrote: ↑Fri Jun 20, 2025 1:50 pmIt looks as if LibreDrive was not enabled for your UHD drive:Not sure why not though... However, even MakeMKV needs a dump that was generated using LibreDrive.Code: Select all
SDF v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO1P31I5206 SDF v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO1P31I5206 SDF v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO1P31I5206 001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E) 003007:0000 Using direct disc access mode ... DAFD=PAAAADAAAAEABDQgEFwECAQ== 002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:5' ... 003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Perhaps try again? The problem might just have been a fluke.
I guess it was a fluke then. Now it rips without any issue
. But ye i tried to rip it for 3 days before i posted this. Downloaded keys etc reinstalled makemkv and it still said same no key
Firmware should be right one for this drive
OS device name: /dev/sr1
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 81
Firmware version: 1.03
Its Verbatim drive that is pretty much rebranded LG so i flashed it with this DE_LG_BU40N_1.03_MK.bin from all in one firmware pack from martymcnuts and i have ripped 30 UHD movies with it already without issues. The Fast and the Furious 1 was first movie with issues but it rips fine now.
Revision: 1.03
Serial number:
Could you provide the discatt.dat file that MakeMKV created for this disk please? I think it might be able to tell The Powers That KEYDB something new.
Yep, must have not used libredrive for that session for some reason.... Your drive info looks fine.TomPPaZ wrote: ↑Sun Jun 22, 2025 9:45 amI guess it was a fluke then. Now it rips without any issue. But ye i tried to rip it for 3 days before i posted this. Downloaded keys etc reinstalled makemkv and it still said same no key
Revision: 1.03
Serial number:
