The fast and the furious 4K UHD Key not Present
TomPPaZ
Post by TomPPaZ » Fri Jun 20, 2025 6:53 am
Tried adding newest KEYDB.CFG to /home/user/.MakeMKV folder without luck
ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT'
Moviepack was bought from coolshop and it is fast and furious 9 movie collection. Other disks rip fine but not the first movie
MakeMKV dump file
https://drive.google.com/file/d/1fhMMD6 ... drive_link
MrPenguin
Re: The fast and the furious 4K UHD Key not Present
Post by MrPenguin » Fri Jun 20, 2025 1:50 pm
TomPPaZ wrote: Fri Jun 20, 2025 6:53 am Tried adding newest KEYDB.CFG to /home/user/.MakeMKV folder without luck
It looks as if LibreDrive was not enabled for your UHD drive:
SDF  v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO1P31I5206
001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E)
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:5'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Not sure why not though... However, even MakeMKV needs a dump that was generated using LibreDrive.
TomPPaZ
Post by TomPPaZ » Fri Jun 20, 2025 11:39 pm
Weird since i have flashed my drive with libredrive enabled firmware and it rips other 4K movies
Post by MartyMcNuts » Fri Jun 20, 2025 11:53 pm
MrPenguin wrote: Fri Jun 20, 2025 1:50 pm
It doesn't look like you have flashed the drive with libredrive compatible firmware. Can you post your MakeMKV drive info / libredrive info sections.
MrPenguin
Post by MrPenguin » Sat Jun 21, 2025 7:20 pm
TomPPaZ wrote: Fri Jun 20, 2025 11:39 pm Weird since i have flashed my drive with libredrive enabled firmware and it rips other 4K movies
Perhaps try again? The problem might just have been a fluke.
TomPPaZ
Post by TomPPaZ » Sun Jun 22, 2025 9:45 am
I guess it was a fluke then. Now it rips without any issue :roll: . But ye i tried to rip it for 3 days before i posted this. Downloaded keys etc reinstalled makemkv and it still said same no key
Firmware should be right one for this drive
OS device name: /dev/sr1
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 81
Firmware version: 1.03
Its Verbatim drive that is pretty much rebranded LG so i flashed it with this DE_LG_BU40N_1.03_MK.bin from all in one firmware pack from martymcnuts and i have ripped 30 UHD movies with it already without issues. The Fast and the Furious 1 was first movie with issues but it rips fine now.
MrPenguin
Post by MrPenguin » Sun Jun 22, 2025 6:31 pm
TomPPaZ wrote: Sun Jun 22, 2025 9:45 am I guess it was a fluke then. Now it rips without any issue :roll: . But ye i tried to rip it for 3 days before i posted this. Downloaded keys etc reinstalled makemkv and it still said same no key
Could you provide the discatt.dat file that MakeMKV created for this disk please? I think it might be able to tell The Powers That KEYDB something new.
Post by MartyMcNuts » Mon Jun 23, 2025 2:53 am
Revision: 1.03
Serial number:
Yep, must have not used libredrive for that session for some reason.... Your drive info looks fine.
