AACS v64 Blu-ray Disc Info submission
XeRnUno
#1 Post by XeRnUno » Thu Jun 12, 2025 4:45 pm
Well, it's a 8 year old BD, but no matter what, it can't be ripped/read.
Open the Disc is possible, so no dump :(
Got this Disc Infos:
Getting disc info...
Validation Data: E3C892B9FDBF8EF01EF8B0D55D5075B8 [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0xC018054D1C782A96F001EADBC5AB6282F014A942
[Volume]: BDROM
[Date]: 2017-12-12
[VID]: 0x3CDEDFEB2CF055A66A2BCE8ABF8FF1FE
[MKB]: 64
[EncKey]: 1-0x647E9BA974EA010EE1FC4AAA58E10DD8
[KEYDB_STATUS]:
[STATUS]: not found
[DiscType]: BD
Validating disc...
17:40:49 -  ----------- FindVUK 1.82 -----------
 To close FindVUK simply press the ESC key
17:40:49 - MODE: ValidateDisc
17:40:49 -  DriveLetter  : L
17:40:49 - SettingsFile: >D:\APPS\MEDIA\DVD\VOB\BR-KEY\FindVUK\config\FindVUK.ini<
17:40:49 - Logfile >D:\APPS\MEDIA\DVD\VOB\BR-KEY\FindVUK\log\2025-06-12_FindVUK.txt< Default Loglevel >2<
17:40:49 - Update enabled - check for update
17:40:49 - No update required
17:40:49 - Open Main-KEYDB file: >C:\Users\DANIEL\AppData\Roaming\aacs\KEYDB.cfg<
17:40:53 - Open Backup-KEYDB file: >D:\APPS\MEDIA\DVD\VOB\BR-KEY\FindVUK\VUKbackup\KEYDB.cfg<
17:40:53 - Get basic AACS data
17:40:53 - AACS folder on disc is reachable - Validate is possible
17:40:54 - VolumeName         >BDROM<
17:40:54 - DiscId             >C018054D1C782A96F001EADBC5AB6282F014A942< (2017-12-12)
17:40:54 - DiscType           >BD<
17:40:54 - MKB Revision       >64<
17:40:54 - Disc-BusEncEnabled >0<
17:40:54 - Drve-BusEncCapable >1<
17:40:54 - UnitKeyCount       >1<
17:40:54 -  >>> UnitKeyENC (1) >647E9BA974EA010EE1FC4AAA58E10DD8<
17:40:54 - No entry for discid >C018054D1C782A96F001EADBC5AB6282F014A942< available in keydb >C:\Users\DANIEL\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
17:40:54 - Eject the disc now from drive >L:\<
17:40:58 - Successfully ejected the media in drive L!
It's the Disc 4 - of Hatchet the complete Collection - Victor Crowley.
Is it possible with this infos to create a new entry in the KeyDB.cfg?
Re: AACS v64 Blu-ray Disc Info submission
#2 Post by SamuriHL » Thu Jun 12, 2025 6:31 pm
You'd need to post the tgz dump file. Then people can take a look.
MrPenguin
#3 Post by MrPenguin » Thu Jun 12, 2025 8:15 pm
XeRnUno wrote: Thu Jun 12, 2025 4:45 pm
But this disk does have an entry in KEYDB.cfg :|. (So maybe the answer to your question was "yes"?)
XeRnUno
#4 Post by XeRnUno » Fri Jun 13, 2025 11:01 am
Thanks for answering.
SamuriHL wrote: Thu Jun 12, 2025 6:31 pm You'd need to post the tgz dump file. Then people can take a look.
Would do this, but I don't have a dump.
Google says, it is generated, when a disc can't be opened. But I can, ripping progress stops at 1960 MB. :c
MrPenguin wrote: Thu Jun 12, 2025 8:15 pm But this disk does have an entry in KEYDB.cfg :|. (So maybe the answer to your question was "yes"?)
My KEYDB.cfg doesn't have this Disc ID: 0xC018054D1C782A96F001EADBC5AB6282F014A942
:o
Got it from here. http://fvonline-db.bplaced.net
Can you post the line, that I need, or point me to your KEYDB.cfg?
Would be great.
MrPenguin
#5 Post by MrPenguin » Sat Jun 14, 2025 10:25 am
XeRnUno wrote: Fri Jun 13, 2025 11:01 am Got it from here. http://fvonline-db.bplaced.net
Re-download the KEYDB.cfg file, and look for the line that starts
0xC018054D1C782A96F001EADBC5AB6282F014A942 = BDROM | D | 2017-12-28 | ...
#6 Post by SamuriHL » Sat Jun 14, 2025 11:28 am
If it opens and "stops" then it's a disc or drive problem not a protection issue. Clean the disc "even if it looks pristine" or try a different drive.
