Queen I Blu-ray volume key is unknown for this disc
qwertyblurays
#1 Post by qwertyblurays » Fri Jun 13, 2025 2:21 pm
Just received Queen I and can't rip it.
MakeMKV v1.18.1 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/xxxxxxxxxx/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.04 MO9L91B3620d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=FA108BB7DA63)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?kwz6dKrxkq33LJ...
Saved AACS dump file as /Users/xxxxxxxxxx/Library/MakeMKV/MKB_v82_QUEEN_I_DC60.tgz
DEBUG: Code 0 at |h#6ky{XZBv<G Ow:213132721
DEBUG: Code 0 at |h#6ky{XZBv<G Ow:213131341
Debug log started at Fri Jun 13 14:15:39 2025 , written by MakeMKV v1.18.1 darwin(arm64-release)
001005:0000 MakeMKV v1.18.1 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/xxxxxxxxxx/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.64.0 (x86_64-apple-darwin24.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.04 MO9L91B3620d" opened in OS access mode.
SDF v098: HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MO9L91B3620
001011:0000 Using LibreDrive mode (v06.3 id=FA108BB7DA63)
DEBUG: Code 2147483648 at 3Z_2PawM&|Z!?'4q:121265499
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?kwz6dKrxkq33LJfUCyhm4Omma7OET4dPnbME/qRmLuXELEYw/Ra3aIob4o0ALQ==
Re: Queen I Blu-ray volume key is unknown for this disc
#2 Post by MartyMcNuts » Sat Jun 14, 2025 12:47 am
qwertyblurays wrote: Fri Jun 13, 2025 2:21 pm Just received Queen I and can't rip it.
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?kwz6dKrxkq33L ... ob4o0ALQ==
Email the generated TGZ dump file to svq@makemkv.com so that a key can be added to MakeMKV's hashed keys. Additionally, you can also attach your dump file here so a key may also be added to the public KeyDB database.
qwertyblurays
#3 Post by qwertyblurays » Sat Jun 14, 2025 1:04 am
Sent.
MrPenguin
#4 Post by MrPenguin » Sat Jun 14, 2025 3:50 pm
qwertyblurays wrote: Sat Jun 14, 2025 1:04 amSent.
Could you also make that TGZ dump file available here please, either as an attachment or via a download link? This would allow The Powers That KEYDB to try to support your disk too.
qwertyblurays
#5 Post by qwertyblurays » Sat Jun 14, 2025 4:27 pm
Here it is.
Si6776
#6 Post by Si6776 » Mon Mar 30, 2026 5:08 pm
Hi all,
I'm having problems with this disc as well, so thought I'd jump on here rather than start a new thread.
My problem is that it seems to rip OK, and I have the files in the backup folder as normal, but when I try to pull the audio out with DVD Audio Extractor, it's only giving me mono files and not the 5.1 audio. If I use the Direct stream demux function in DVDAE, it gives me *.thd files, but these are all 0kb and unplayable.
I didn't have this problem with the new Rush Grace Under Pressure bluray, and I have the latest update of MakeMKV, so I'm wondering what I'm doing wrong?
