Open the Disc is possible, so no dump
Got this Disc Infos:
Getting disc info...
Validation Data: E3C892B9FDBF8EF01EF8B0D55D5075B8 [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0xC018054D1C782A96F001EADBC5AB6282F014A942
[Volume]: BDROM
[Date]: 2017-12-12
[VID]: 0x3CDEDFEB2CF055A66A2BCE8ABF8FF1FE
[MKB]: 64
[EncKey]: 1-0x647E9BA974EA010EE1FC4AAA58E10DD8
[KEYDB_STATUS]:
[STATUS]: not found
[DiscType]: BD
Validating disc...
17:40:49 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
17:40:49 - MODE: ValidateDisc
17:40:49 - DriveLetter : L
17:40:49 - SettingsFile: >D:\APPS\MEDIA\DVD\VOB\BR-KEY\FindVUK\config\FindVUK.ini<
17:40:49 - Logfile >D:\APPS\MEDIA\DVD\VOB\BR-KEY\FindVUK\log\2025-06-12_FindVUK.txt< Default Loglevel >2<
17:40:49 - Update enabled - check for update
17:40:49 - No update required
17:40:49 - Open Main-KEYDB file: >C:\Users\DANIEL\AppData\Roaming\aacs\KEYDB.cfg<
17:40:53 - Open Backup-KEYDB file: >D:\APPS\MEDIA\DVD\VOB\BR-KEY\FindVUK\VUKbackup\KEYDB.cfg<
17:40:53 - Get basic AACS data
17:40:53 - AACS folder on disc is reachable - Validate is possible
17:40:54 - VolumeName >BDROM<
17:40:54 - DiscId >C018054D1C782A96F001EADBC5AB6282F014A942< (2017-12-12)
17:40:54 - DiscType >BD<
17:40:54 - MKB Revision >64<
17:40:54 - Disc-BusEncEnabled >0<
17:40:54 - Drve-BusEncCapable >1<
17:40:54 - UnitKeyCount >1<
17:40:54 - >>> UnitKeyENC (1) >647E9BA974EA010EE1FC4AAA58E10DD8<
17:40:54 - No entry for discid >C018054D1C782A96F001EADBC5AB6282F014A942< available in keydb >C:\Users\DANIEL\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
17:40:54 - Eject the disc now from drive >L:\<
17:40:58 - Successfully ejected the media in drive L!
Is it possible with this infos to create a new entry in the KeyDB.cfg?
