Can I see what discs are already in the HK table?
Kezza
#1 Post by Kezza » Wed Jun 11, 2025 10:03 pm
I have 2 discs that refuse to rip, I just doubt the keys havent been generated as they was released in December 2022 (Halloween Kills and Halloween Ends, from the Halloween Trilogy 4K edition). I feel like as it was released so long ago, and the fact the first disc (Halloween) ripped fine means something else is up and its not missing keys? I reinstalled MakeMKV despite being on the latest version just to make sure it downloaded the latest HK and I can see in the logs that it did, Downloading latest HK to C:\Users\xxxx/.MakeMKV ... but I just get the Saved AACS dump file and The volume key is unknown for this disc - video can't be decrypted error for both. Can I check if the keys are in the HK MakeMKV downloaded?
jayper
Re: Can I see what discs are already in the HK table?
#2 Post by jayper » Thu Jun 12, 2025 2:31 pm
To my knowledge, no you can't see the contents of the HK file. However, if they're not ripping and dump files are being created you can feel confident that your discs are not in the HK database. Just because the movies were releases a long time ago, it doesn't mean your specific disc IDs were dumped. The same movie can have many variants. Submit your dump files.
Also, check this thread for helpful information around using the public Keydb file, which is another avenue you can take: viewforum.php?f=12
MrPenguin
#3 Post by MrPenguin » Thu Jun 12, 2025 2:36 pm
Kezza wrote: Wed Jun 11, 2025 10:03 pm I have 2 discs that refuse to rip, I just doubt the keys havent been generated as they was released in December 2022 (Halloween Kills and Halloween Ends, from the Halloween Trilogy 4K edition). I feel like as it was released so long ago, and the fact the first disc (Halloween) ripped fine means something else is up and its not missing keys?
Most likely, your disks are not in MakeMKV's "hashed keys" database. Another possibility might be that your drive has not enabled LibreDrive, which would prevent MakeMKV from decrypting your disks even if their Unit Keys were already known.
You could also check whether the public KEYDB.cfg file contains your keys. Just copy this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
Kezza
#4 Post by Kezza » Thu Jun 12, 2025 4:10 pm
MrPenguin wrote: Thu Jun 12, 2025 2:36 pm
I have ripped other 4K discs with my Verbatim 43888 drive just fine, and MakeMKV says its LibreDrive enabled so confident the drive is fine. I have downloaded the keydb.cfg and have checked it and can see the films in the file, but again, still wont decrypt. Not sure if maybe its a different version in the keydb.cfg like you and others have said could be the case for the HK db, but again, not sure how to verify that.
Does MakeMKV ever log when it succesfully downloads the HK db, as I can see that downloads starts, but no confirmation it completes. Not sure if that is normal behaviour or not, but just concered that some DNS providers block access to the DB server so worried maybe it isnt getting downloaded correctly? I am using cloudflare DNS
MrPenguin
#5 Post by MrPenguin » Thu Jun 12, 2025 4:14 pm
Kezza wrote: Thu Jun 12, 2025 4:10 pm I have ripped other 4K discs with my Verbatim 43888 drive just fine, and MakeMKV says its LibreDrive enabled so confident the drive is fine. I have downloaded the keydb.cfg and have checked it and can see the films in the file, but again, still wont decrypt. Not sure if maybe its a different version in the keydb.cfg like you and others have said could be the case for the HK db, nut again, not sure how to verify that
There are usually several different variants of each disk, and there's no guarantee that either MakeMKV's "hashed keys" database or KEYDB.cfg will contain them all. All you can do is email your TGZ dump files to svq@makemkv.com and wait, and possibly try to share them here as well. However, if your Verbatim 43888 drive contains a Pioneer UD04 then I doubt The Powers That KEYDB will be able to help you :(. (Although you also seem to be using Windows, so make KEYDB + Xreveal could work?)
Sharing your TGZ dump files here would allow people to offer you a more informed opinion though ;).
Kezza
#6 Post by Kezza » Thu Jun 12, 2025 8:50 pm
MrPenguin wrote: Thu Jun 12, 2025 4:14 pm
I have sent the dump files in now :)
MKB20_v76_Halloween_Kills_7EF1
MKB20_v77_Halloween_Ends_391D
MrPenguin
#7 Post by MrPenguin » Thu Jun 12, 2025 9:08 pm
Kezza wrote: Thu Jun 12, 2025 8:50 pm I have sent the dump files in now :)
Could you also share those dump files here please? I doubt that The Powers That KEYDB will be able to determine their VUKs for you, but they could still be useful in the long term.
Kezza
#8 Post by Kezza » Thu Jun 12, 2025 10:36 pm
MrPenguin wrote: Thu Jun 12, 2025 9:08 pm
Dump files:
MrPenguin
#9 Post by MrPenguin » Thu Jun 12, 2025 11:10 pm
Kezza wrote: Thu Jun 12, 2025 10:36 pm Dump files:
Thanks for these. Could you also include the AACS/MKB_RO.inf files from their physical UHD disks please? The copies of these files inside the TGZ dump files have been truncated to only 56 bytes, which makes them unusable to anyone except MakeMKV itself.
Note that MKB_RO.inf files are big, so you will need to ZIP them.
