War of the Worlds (1953) dump submitted
NotaNumber
Post by NotaNumber » Tue Jun 10, 2025 3:18 pm
Not found in latest KEYDB.CFG
Submitted dump file (email):
MKB20_v77_The_War_of_the_Worlds_(1953)_-_Remastered_5411.tgz
MrPenguin
Re: War of the Worlds (1953) dump submitted
Post by MrPenguin » Tue Jun 10, 2025 3:32 pm
Could you also provide your dump file here please, either as an attachment or via a download link? This would allow The Powers That KEYDB to try to support your disk as well.
NotaNumber
Post by NotaNumber » Wed Jun 11, 2025 1:18 am
MrPenguin
Post by MrPenguin » Wed Jun 11, 2025 11:01 am
Quota Full
DL link provided:
Thanks, and could you also provide the actual MKB_RO.inf file from your disk's AACS/ directory please? The copy of this file inside the TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV.
MrPenguin
Post by MrPenguin » Wed Jun 11, 2025 11:54 am
NotaNumber wrote:
Wed Jun 11, 2025 11:38 am
Here you go:
Thanks. The latest KEYDB.cfg file contains a Unit Key for this disk, but not a Volume Unique Key (VUK). Do you also have access to a non-Pioneer UHD drive please, to provide the final piece of information so that The Powers That KEYDB can try to calculate the VUK? Otherwise, you could still use Xreveal to help MakeMKV decrypt your disk.
NotaNumber
Post by NotaNumber » Wed Jun 11, 2025 2:41 pm
Unfortunately all I have is a Pioneer drive. I'll check out Xreveal, thanks for the help.
dillspooch
Post by dillspooch » Mon Sep 22, 2025 4:27 pm
I have this War of the Worlds 4K disc and have experienced the same problem.
I see the following in MAkeMKV....
Using LibreDrive mode (v01.0 id=2AE09FD4F501)
Saved AACS dump file as C:\Users\mike/.MakeMKV/MKB20_v77_The_War_of_the_Worlds_(1953)_-_Remastered_786B.tgz
I have a Pioneer drive.
I don't really understand the messages in this thread in particular about Xreveal. I have installed it, download keydb.cfg. I don't know how I can extract the movie using this.
MrPenguin
Post by MrPenguin » Mon Sep 22, 2025 10:07 pm
The public KEYDB.cfg file would need to contain your disk's Unit Key before Xreveal could decrypt your disk. Could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? Because you have a Pioneer drive there is no guarantee that this would help, but it might still be worth trying.
