Sean Connery June 9th 4K box set Attached TGZ files
MrPenguin
Re: Sean Connery June 9th 4K box set Attached TGZ files
Post by MrPenguin »
Armatage wrote: Tue Jun 10, 2025 9:09 pm I emailed the dump tiles to svq@makemkv.com
Attached TGZ files
ONLY LIVE TWICE
THUNDERBALL
GOLDFINGER
DIAMONDS ARE FOREVER
FROM RUSSIA WITH LOVE
DR NO
If your dumps are exactly the same variants as these then they should already be in the latest KEYDB.cfg file. So just download it, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
Or wait until MakeMKV processes your TGZ dump files, of course :).
WAYFLIX
Post by WAYFLIX »
All work in keydb
Armatage
Post by Armatage »
Hi
I downloaded the Keydb , but it a zip file ... do i uncompress it or leave it in the .zip file formoat ?
thanks
A
Armatage wrote: Tue Jun 10, 2025 11:45 pm Hi
thanks
A
Uncompress and copy the KeyDB.cfg file from it to the MakeMKV data directory (where the .tgz dumps are)
