Hello
i emailed the dump tiles to svq@makemkv.com
Attached TGZ files LINKS
ONLY LIVE TWICE
https://drive.google.com/file/d/1aXx7Pb ... sp=sharing
THUNDERBALL
https://drive.google.com/file/d/1FLOW8o ... sp=sharing
GOLDFINGER
https://drive.google.com/file/d/1qrQW0J ... sp=sharing
DIAMONDS ARE FOREVER
https://drive.google.com/file/d/1v25wu- ... sp=sharing
FROM RUSSIA WITH LOVE
https://drive.google.com/file/d/194btpY ... sp=sharing
DR NO
https://drive.google.com/file/d/1KBq-jF ... sp=sharing
thnak you for all the support
Sean Connery June 9th 4K box set Attached TGZ files
Armatage
MrPenguin
Re: Sean Connery June 9th 4K box set Attached TGZ files
If your dumps are exactly the same variants as these then they should already be in the latest KEYDB.cfg file. So just download it, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.Armatage wrote: Tue Jun 10, 2025 9:09 pm I emailed the dump tiles to svq@makemkv.com
Attached TGZ files
ONLY LIVE TWICE
THUNDERBALL
GOLDFINGER
DR NO
Or wait until MakeMKV processes your TGZ dump files, of course
WAYFLIX
All work in keydbArmatage wrote: Tue Jun 10, 2025 9:09 pm Hello
ONLY LIVE TWICE
THUNDERBALL
GOLDFINGER
DR NO
Armatage
Hi
I downloaded the Keydb , but it a zip file ... do i uncompress it or leave it in the .zip file formoat ?
thanks
A
thanks
A
Uncompress and copy the KeyDB.cfg file from it to the MakeMKV data directory (where the .tgz dumps are)Armatage wrote: Tue Jun 10, 2025 11:45 pm Hi
thanks
A
