Oppenheimer (2023)
datatracer
Re: Oppenheimer (2023)
#166 Post by datatracer » Tue Jul 30, 2024 3:04 am
How large should dump files be?
The dump file I emailed last week (MKB20_v77_Oppenheimer_228A.tgz) is: 3.31 MB (3,476,662 bytes)
I'm not sure if that's normal or too large?
I'm still unable to rip the 4k disc.
Using MakeMKV version 1.17.7 on Windows 10, 64-bit. No internet connection issues.
MrPenguin
#167 Post by MrPenguin » Tue Jul 30, 2024 9:37 am
That sounds about right. Have you checked your private messages?
datatracer
#168 Post by datatracer » Tue Jul 30, 2024 8:33 pm
I did and replied. Thanks!
datatracer
#169 Post by datatracer » Wed Jul 31, 2024 4:28 pm
My version of Oppenheimer 4K (MKB20_v77_Oppenheimer_228A.tgz) is now working!
Not sure if it was MakeMKV or the updated KEYDB.cfg that did it, but it works now 😁👍
Thank you!
VarHD
#170 Post by VarHD » Fri Nov 22, 2024 5:05 pm
Dump for MKB20_v77_OPPENHEIMER_CB94.tgz sent.
---EDIT---
Works now, thanks!
monico
#171 Post by monico » Tue Jun 10, 2025 12:03 am
Dump for MKB20_v77_Oppenheimer_F7C9.tgz sent.
---EDIT---
Works now, at least with the KEYDB.cfg file, Thanks! :D
MrPenguin
#172 Post by MrPenguin » Tue Jun 10, 2025 10:05 am
Could you also make this TGZ dump file available here please, either as an attachment or via a download link? This would allow The Powers That KEYDB to try to add your disk to the public KEYDB.cfg file.
monico
#173 Post by monico » Tue Jun 10, 2025 2:20 pm
Here’s the dump.
