Dumps submitted for The Quatermass Xperiment
Mister_Glyn
Post by Mister_Glyn »
Dumps have just been submitted for The Quatermass Xperiment UHD:
MKB20_v82_THE_QUATERMASS_XPERIMENT_8DFC.tgz and MKB20_v82_THE_QUATERMASS_XPERIMENT_B038.tgz.
Many thanks!
MrPenguin
Re: Dumps submitted for The Quatermass Xperiment
Post by MrPenguin »
Mister_Glyn wrote:
Sun Jun 08, 2025 8:19 pm
Could you also make your TGZ dump file available here please, either as an attachment or via a download link? This would help The Powers That KEYDB to support your disk.
Mister_Glyn
Sure, no worries 8) Dumps should be accessible from here.
keydb_helper
Post by keydb_helper »
Many thanks!
Thanks for providing suitable disc dumps. Both of your The Quatermass Xperiment discs have been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Mister_Glyn
No problem, and thanks! Confirmed as working 8)
