Dexter: Original Sin Season 1 AACS dump file
thundernathan14
Post by thundernathan14 »
Disc 1 is not working
Disc 2 is working
Disc 3 is working
MrPenguin
Re: Dexter: Original Sin Season 1 AACS dump file
Post by MrPenguin »
thundernathan14 wrote:
Mon Jun 09, 2025 1:13 pm
Disc 2 is working
Disc 3 is working
SamuriHL has written a utility which can add the latest KEYDB.cfg file into your MAkeMKV installation. Does this help? And if so, could you also use it to validate these disks please?
Post by SamuriHL »
It's in the keydb. Either manually extract the keydb.cfg file to your MakeMKV data directory or you can use my Windows tool to do it for you:
viewtopic.php?f=12&t=16883&p=166510#p166510
thundernathan14
MrPenguin wrote:
Mon Jun 09, 2025 1:34 pm
Disc 2 is working
Disc 3 is working
thx it work
