Dexter: Original Sin Season 1 AACS dump file
Disc 1 is not working
Disc 2 is working
Disc 3 is working
thundernathan14
MrPenguin
Re: Dexter: Original Sin Season 1 AACS dump file
SamuriHL has written a utility which can add the latest KEYDB.cfg file into your MAkeMKV installation. Does this help? And if so, could you also use it to validate these disks please?thundernathan14 wrote: Mon Jun 09, 2025 1:13 pm Dexter: Original Sin Season 1 AACS dump file
Disc 2 is working
Disc 3 is working
It's in the keydb. Either manually extract the keydb.cfg file to your MakeMKV data directory or you can use my Windows tool to do it for you:
viewtopic.php?f=12&t=16883&p=166510#p166510
thundernathan14
thx it workMrPenguin wrote: Mon Jun 09, 2025 1:34 pmSamuriHL has written a utility which can add the latest KEYDB.cfg file into your MAkeMKV installation. Does this help? And if so, could you also use it to validate these disks please?thundernathan14 wrote: Mon Jun 09, 2025 1:13 pm Dexter: Original Sin Season 1 AACS dump file
Disc 2 is working
Disc 3 is working
