Dexter: Original Sin Season 1 AACS dump file
thundernathan14
#1 Post by thundernathan14 » Mon Jun 09, 2025 1:13 pm
Disc 1 is not working
Disc 2 is working
Disc 3 is working
MrPenguin
Re: Dexter: Original Sin Season 1 AACS dump file
#2 Post by MrPenguin » Mon Jun 09, 2025 1:34 pm
thundernathan14 wrote: Mon Jun 09, 2025 1:13 pm Dexter: Original Sin Season 1 AACS dump file
Disc 2 is working
Disc 3 is working
SamuriHL has written a utility which can add the latest KEYDB.cfg file into your MAkeMKV installation. Does this help? And if so, could you also use it to validate these disks please?
#3 Post by SamuriHL » Mon Jun 09, 2025 1:41 pm
It's in the keydb. Either manually extract the keydb.cfg file to your MakeMKV data directory or you can use my Windows tool to do it for you:
viewtopic.php?f=12&t=16883&p=166510#p166510
thundernathan14
#4 Post by thundernathan14 » Mon Jun 09, 2025 5:31 pm
MrPenguin wrote: Mon Jun 09, 2025 1:34 pm
Disc 2 is working
Disc 3 is working
thx it work
