Here are 3 Bluray I can't decrypt
MakeMKV v1.18.1
KeyDB.cfg updated a few minutes ago
Is there a howto doc to find the key ourself?
AACS v82 Blu-ray Disc dump Submission
- MKB_v82_EPCE_7923_4930.tgz
- (58.69 KiB) Downloaded 63 times
- MKB_v82_EPCE_7921_9C5E.tgz
- (1.92 MiB) Downloaded 49 times
- MKB_v82_EPCE_7919_EDC6.tgz
- (1.9 MiB) Downloaded 52 times
Re: AACS v82 Blu-ray Disc dump Submission
They're already in the keydb from what I can see. Make sure you extract the keydb.cfg file to your MakeMKV data directory. Additionally if you're on Windows, this post might help. Read it thoroughly.
viewtopic.php?f=12&t=16883&p=166510#p166510
Yes, I have used FindVUK just after posting here.
But MakeMKV is still not able to uncrypt them.
I tried on my both Bluray readers (one is on LibreDrive Firmware).
Update, Status has changed since yesterday for my discs \o/
[(Disc Info)]
[DiscID]: 0x7B2176FB2EDC16368373D24F1AFD594D1B95C946
[Volume]: EPCE_7921
[Date]: 2025-03-17
[MediaKey]: 0xC8555EB5A0031AA2FCE66C7CE5E9047D
[VID]: 0xD59FA1389AB8F2A98FAFBDD4823D5FA6
[VUK]: 0xACB082EDF2A10550C18362E9A2E1DEF3
[MKB]: 82
[UnitKey]: 1-0xF614D2D60A68CC717CD02CAD69E1CAA4
[KEYDB_STATUS]: (VALIDATED)
[STATUS]: complete
[DiscType]: BD
[(Disc Info)]
[Volume]: EPCE_7921
[Date]: 2025-03-17
[MKB]: 82
[STATUS]: complete
[DiscType]: BD
Yes, I used the KeyDB Helper utility who done this directly for me.
I was able to dump my discs.
Thanks for helping me
