Kill Bill Vol. 1 Dump Submitted
oatmeal769
Re: Kill Bill Vol. 1 Dump Submitted
Post by oatmeal769 » Fri Jun 06, 2025 2:37 pm
MrPenguin wrote: Fri Jun 06, 2025 1:45 pm You have provided a file called _private_data.tar here. The MKB20_v77_Kill_Bill-_Vol_1_ABCD.tgz file (if it exists) would be in the same directory as _private_data.tar.
A .tar file is a container, like a .zip file. I suspect that you have accidentally "opened" the .tar file and mistaken it for a directory.
What does MakeMKV's log output say?
There is only the private_data.tar and keydb.cfg in the database folder.
Inside the private-data.tar are a bunch of .bin files, and one .tgz called "MKB20_v77_save.tgz"
Inside MKB20_v77_save.tgz" are an AACS folder, discatt.dat, and log.txt.
log.txt says this:
Debug log started at Thu Jun 05 01:21:17 2025 , written by MakeMKV v1.18.1 win(x64-release)
001005:0000 MakeMKV v1.18.1 win(x64-release) started
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF v098: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLBO6R83258
MrPenguin
Post by MrPenguin » Fri Jun 06, 2025 2:41 pm
oatmeal769 wrote: Fri Jun 06, 2025 2:37 pm SDF v098: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLBO6R83258
What does MakeMKV's "Info" window say under "LibreDrive Information"? Does it say whether LibreDrive is enabled?
We shouldn't need to drill down into _private_data.tar at this stage.
oatmeal769
Post by oatmeal769 » Fri Jun 06, 2025 2:46 pm
MrPenguin wrote: Fri Jun 06, 2025 2:41 pm What does MakeMKV's "Info" window say under "LibreDrive Information"? Does it say whether LibreDrive is enabled?
Yes, LibreDrive is enabled
MrPenguin
Post by MrPenguin » Fri Jun 06, 2025 2:50 pm
oatmeal769 wrote: Fri Jun 06, 2025 2:46 pm Yes, LibreDrive is enabled
Does MakeMKV allow you to create a back-up of your disk? (Obviously an encrypted backup, since you cannot decrypt the disk yet.)
oatmeal769
Post by oatmeal769 » Fri Jun 06, 2025 2:54 pm
MrPenguin wrote: Fri Jun 06, 2025 2:50 pm
[/quote]I don't know, but I'll try now.
I also just enabled "Log debug messages" in the "General" tab. Maybe that will help generate what you need. Stand by...
MrPenguin
Post by MrPenguin » Fri Jun 06, 2025 2:57 pm
oatmeal769 wrote: Fri Jun 06, 2025 2:54 pm I also just enabled "Log debug messages" in the "General" tab. Maybe that will help generate what you need. Stand by...
The "debug" messages seem to be written by MakeMKV developers for MakeMKV developers, and so I doubt they'll mean anything to me. However, when MakeMKV creates an encrypted backup, one of the first files that it creates is called discatt.dat. This discatt.dat file should be useful, if you could provide it please?
oatmeal769
Post by oatmeal769 » Thu Jun 12, 2025 5:24 pm
Disk is validated and now exists in KEYDB.cfg, and is synchronized online. STILL can't rip.
MrPenguin
Post by MrPenguin » Thu Jun 12, 2025 7:18 pm
oatmeal769 wrote: Thu Jun 12, 2025 5:24 pm Disk is validated and now exists in KEYDB.cfg, and is synchronized online. STILL can't rip.
Your problem cannot be a decryption problem, since your disk has a validated entry in KEYDB. Can you create a decrypted back-up of this disk? Can you even copy the contents of this disk to your hard drive without using MakeMKV?
oatmeal769
Post by oatmeal769 » Thu Jun 12, 2025 8:47 pm
MrPenguin wrote: Thu Jun 12, 2025 7:18 pmCan you create a decrypted back-up of this disk?
Yes.
Aaaannnd, then it ripped successfully. IDK how, but all is well now! Thank you so much; I learned a lot!
lfoust
Post by lfoust » Fri Jun 20, 2025 12:38 am
I was able to rip successfully. Here is how it played out https://thediscdb.com/movie/kill-bill-v ... es/2025-4k
