Kill Bill Vol. 1 Dump Submitted
Ralph P.
Post by Ralph P. » Fri Jan 17, 2025 1:03 pm
Greetings,
MKB20_v77_Kill_Bill-_Vol_1_1730
The file has also been uploaded to Google Drive for Keydb.
Regards,
Ralph P.
Re: Kill Bill Vol. 1 Dump Submitted
Post by Ralph P. » Sat Jan 18, 2025 3:06 pm
Greetings,
This title now rips using the latest Keydb file. Thank you!
Regards,
buttscarlton
Post by buttscarlton » Fri Jan 24, 2025 5:32 pm
Likely a silly question, what do I need to do utilize the latest Keydb file? Also, how does one access it? looking to make an mkv of the Kill Bill v1 & v2 UHDs as well. Thanks!
Post by dcoke22 » Sat Jan 25, 2025 4:24 am
buttscarlton wrote: Fri Jan 24, 2025 5:32 pm Likely a silly question, what do I need to do utilize the latest Keydb file? Also, how does one access it? looking to make an mkv of the Kill Bill v1 & v2 UHDs as well. Thanks!
MakeMKV has its own built-in key mechanism called Hashed Keys that it downloads on its own, automatically, as needed assuming your computer or ISP isn't blocking the downloads. Read more in the UHD FAQ.
In addition, you can use the keydb.cfg file as well. Read about it here: https://forum.makemkv.com/forum/viewtopic.php?f=12&t=35942&p=162444#p162444
neo305
Post by neo305 » Sat Jan 25, 2025 10:04 pm
able to rip now? I'm still waiting for mine to be delivered :)
oatmeal769
Post by oatmeal769 » Thu Jun 05, 2025 2:59 pm
I've tried to rip two different copies of the UHD version also. No luck.
DL'd keydb.cfg, also
K.B. Vol. 2 ripped with no issues. Any ideas how to get K.B. Vol. 1 happening?
MrPenguin
Post by MrPenguin » Thu Jun 05, 2025 3:48 pm
oatmeal769 wrote: Thu Jun 05, 2025 2:59 pm I've tried to rip two different copies of the UHD version also. No luck.
Do you have a TGZ dump file for your disk that you could share please, either as an attachment or via a download link? This might allow The Powers That KEYDB to support your disk.
oatmeal769
Post by oatmeal769 » Thu Jun 05, 2025 4:11 pm
MrPenguin wrote: Thu Jun 05, 2025 3:48 pm Do you have a TGZ dump file for your disk that you could share please, either as an attachment or via a download link? This might allow The Powers That KEYDB to support your disk.
Not sure how. Can you point me to a tutorial, and I'll get it posted right away?
MrPenguin
Post by MrPenguin » Thu Jun 05, 2025 4:14 pm
oatmeal769 wrote: Thu Jun 05, 2025 4:11 pm
Is there a file called (e.g.) MKB20_v77_Kill_Bill-_Vol_1_ABCD.tgz in MakeMKV's data directory? You can see where MakeMKV's data directory is by looking in MakeMKVs View/Preferences/General menu dialog.
oatmeal769
Post by oatmeal769 » Thu Jun 05, 2025 4:24 pm
MrPenguin wrote: Thu Jun 05, 2025 4:14 pm Is there a file called (e.g.) MKB20_v77_Kill_Bill-_Vol_1_ABCD.tgz in MakeMKV's data directory? You can see where MakeMKV's data directory is by looking in MakeMKVs View/Preferences/General menu dialog.
yes!
https://drive.google.com/file/d/1b-OPjD ... sp=sharing
MrPenguin
Post by MrPenguin » Thu Jun 05, 2025 4:38 pm
oatmeal769 wrote: Thu Jun 05, 2025 4:24 pm
yes!
Hmm, this dump file contains much, much less than it should... Is this the only TGZ dump you have?
oatmeal769
Post by oatmeal769 » Thu Jun 05, 2025 5:32 pm
MrPenguin wrote: Thu Jun 05, 2025 4:38 pm Hmm, this dump file contains much, much less than it should... Is this the only TGZ dump you have?
Yes. This is the first rip I've done since I reloaded Windows and MkMkV. I had the same issues before my reload with this disc.
I also closed the program before I went looking for the file. Does it erase the dump for that particular rip when the program is closed?
MrPenguin
Post by MrPenguin » Thu Jun 05, 2025 7:09 pm
oatmeal769 wrote: Thu Jun 05, 2025 5:32 pm Yes. This is the first rip I've done since I reloaded Windows and MkMkV. I had the same issues before my reload with this disc.
Actually, I don't believe that TGZ dump file is intended for calculating decryption keys. The dump for "Kill Bill Vol1" should be called something like MKB20_v77_Kill_Bill-_Vol_1_ABCD.tgz, and if it's not present in the data directory then it's almost certainly because MakeMKV hasn't created it.
oatmeal769
Post by oatmeal769 » Fri Jun 06, 2025 1:10 pm
MrPenguin wrote: Thu Jun 05, 2025 7:09 pm Actually, I don't believe that TGZ dump file is intended for calculating decryption keys. The dump for "Kill Bill Vol1" should be called something like MKB20_v77_Kill_Bill-_Vol_1_ABCD.tgz, and if it's not present in the data directory then it's almost certainly because MakeMKV hasn't created it.
Apologies for the delay.
I tried ripping again this morning. This time, I didn't close the program, and I will post what I have here. I'm not sure if it's significantly different, though.
I'm going to post the entire database folder. Maybe it's in there, but I'm not finding it?
LINK:
https://drive.google.com/file/d/1AceW5d ... sp=sharing
MrPenguin
Post by MrPenguin » Fri Jun 06, 2025 1:45 pm
oatmeal769 wrote: Fri Jun 06, 2025 1:10 pm I'm going to post the entire database folder. Maybe it's in there, but I'm not finding it?
You have provided a file called _private_data.tar here. The MKB20_v77_Kill_Bill-_Vol_1_ABCD.tgz file (if it exists) would be in the same directory as _private_data.tar.
A .tar file is a container, like a .zip file. I suspect that you have accidentally "opened" the .tar file and mistaken it for a directory.
What does MakeMKV's log output say?
