Dump submitted for A Working Man
rkhollister
Post by rkhollister » Thu Jun 05, 2025 4:12 pm
MKB20_v82_A_Working_Man_FA3E.tgz
Re: Dump submitted for A Working Man
Post by MartyMcNuts » Fri Jun 06, 2025 3:53 am
rkhollister wrote: Thu Jun 05, 2025 4:12 pm MKB20_v82_A_Working_Man_FA3E.tgz
If you also attach the dump here, we may also be able to add the record to the KeyDB as well.
rkhollister
Post by rkhollister » Fri Jun 06, 2025 3:10 pm
I have Pioneer drives and have been informed the dump file from those is insufficient
Post by MartyMcNuts » Sat Jun 07, 2025 12:11 am
rkhollister wrote: Fri Jun 06, 2025 3:10 pm I have Pioneer drives and have been informed the dump file from those is insufficient
Depends on your drive model. Dumps from most Pioneer's are still ok, just not the UD04 and 211/S11 series, I think.
keydb_helper
Post by keydb_helper » Sat Jun 07, 2025 1:26 am
The complete record for the FA3E variant of A Working Man has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
MartyMcNuts wrote: Sat Jun 07, 2025 12:11 am
With regards to the public keydb, Pioneer disc dumps are generally not sufficient for creating entries from scratch.
There are some possibilities when a "sibling" disc which uses the same media key (MK) is already present in the public keydb. This can occur due to regional variations. In such a circumstance it is possible to create a complete record for your target disc as long as the volume ID (VID) is not obfuscated in the dump file. As you noted, this is currently known to be the case for at least the UD04, 211, and S11 series.
For the FA3E variant of A Working Man there was no prior record of a disc with the same media key, so a dump from an LG/Asus drive was required.
If the media key was already known, a disc dump from a Pioneer XS07U could've been used to generate a complete keydb record. But the same could not be said for a disc dump produced by a Verbatim 43888 with a UD04 drive.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
rkhollister
Post by rkhollister » Sat Jun 07, 2025 11:24 am
Ripping now - thx!
dool1981
Post by dool1981 » Wed Jun 11, 2025 6:53 pm
rkhollister wrote: Sat Jun 07, 2025 11:24 am Ripping now - thx!
What did you do to get it to rip? im still getting "The volume key is unknown for this disc - video can't be decrypted" message. Ive used both a Pioneer and LG drive.
MrPenguin
Post by MrPenguin » Thu Jun 12, 2025 4:02 pm
dool1981 wrote: Wed Jun 11, 2025 6:53 pm What did you do to get it to rip? im still getting "The volume key is unknown for this disc - video can't be decrypted" message.
Have you tried downloading the KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
charnathan
Post by charnathan » Thu Jun 19, 2025 10:59 pm
FA3E is now working for anyone who hasn't tried yet.
Also, glad the site is back up! :D
