Connery Bond Set Dumps Submitted
The following 6 dumps were submitted from the 6 disc set:
MKB20_v77_Dr_No_F274.tgz
MKB20_v77_From_Russia_with_Love_91C0.tgz
MKB20_v82_Goldfinger_F54C.tgz
MKB20_v82_Thunderball_6AE6.tgz
MKB20_v82_You_Only_Live_Twice_9544.tgz
MKB20_v82_Diamonds_are_Forever_5242.tgz
Re: Connery Bond Set Dumps Submitted
Could you also post these dumps here please, either as attachments or via download links? This would allow The Powers That KEYDB to try to help you with these disks too.
Sure - forgot that it was changed to temp allow tgz uploads.
- MKB20_v82_Goldfinger_F54C.tgz
- (3.36 MiB) Downloaded 57 times
- MKB20_v77_From_Russia_with_Love_91C0.tgz
- (3.34 MiB) Downloaded 55 times
- MKB20_v77_Dr_No_F274.tgz
- (3.34 MiB) Downloaded 59 times
Part 2
- MKB20_v82_Diamonds_are_Forever_5242.tgz
- (3.37 MiB) Downloaded 50 times
- MKB20_v82_You_Only_Live_Twice_9544.tgz
- (3.37 MiB) Downloaded 51 times
- MKB20_v82_Thunderball_6AE6.tgz
- (3.38 MiB) Downloaded 60 times
Thanks for these
BTW there might also be some information missing from your TGZ dump files. What does the "LibreDrive" section of MakeMKV's "Info" window say about your drive please?
Came here to do the same. My discs aren't being read either.
I recommend emailing your TGZ dump files to svq@makemkv.com, and if you're also a Windows user then checking KEYDB.cfg periodically with SamuriHL's utility. (This utility would also allow you to validate your disks' KEYDB entries...)
Are your TGZ dump files identical to the OP's?
OverdoneAndDry
I also got my copy early and submitted my TGZ dump files yesterday, but they're not exactly the same as what's been uploaded to this thread. The file sizes are slightly different.
This is my first time with a new 4k where I'm unable to rip the disc because it hasn't been added to the database yet. I don't know how it works, and I can't tell if MakeMKV is correctly accessing the internet (I have it set to look, but I don't see a line in the log--it just says unable to decrypt). I tried the SamuriHL utility and clicked Validate. It detects my drive as a "REAL BLURAY" drive, finds the M2TS files, and then gives an error: "ERROR! Validation of VUK failed >#BRAACS_ListError<"
That sounds like it's to be expected at this stage until everything gets updated?
keydb_helper
All six titles have been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
I think it will be something like:
BD raw metadata read: Partial
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
