Dump Submitted - Sean Connery/James Bond 6-film Collection UHD
OverdoneAndDry
Post by OverdoneAndDry » Wed Jun 04, 2025 4:41 am
I've never done this before. I have these tgz generated for the newly released Sean Connery/James Bond 6-film Collection. Do I still need to email them to svq@makemkv.com or is it okay here?
Re: Dump Submitted - Sean Connery/James Bond 6-film Collection UHD
Post by MartyMcNuts » Fri Jun 06, 2025 3:45 am
OverdoneAndDry wrote: Wed Jun 04, 2025 4:41 am I've never done this before. I have these tgz generated for the newly released Sean Connery/James Bond 6-film Collection. Do I still need to email them to svq@makemkv.com or is it okay here?
Yes, email them.
Post by MartyMcNuts » Fri Jun 06, 2025 3:51 am
Records for all 3 of these discs are in the latest KeyDB file. If you download it and put it in the MakeMKV data directory (where the dumps are) you should be able to rip them.
OverdoneAndDry
Post by OverdoneAndDry » Mon Jun 09, 2025 3:10 am
Thank you. I had trouble emailing more than 1 dump per email, but I did email them.
Also, I have a dumb question. I was able to rip each disc by using the keydb update thing from the SamuriHL utility. Just checking, but is that a separate/alternate database than what "comes with" MakeMKV? I'm still not exactly sure how it works, but a couple days ago, after validating the disc in SamuriHL, I was able to rip them in MakeMKV.
MrPenguin
Post by MrPenguin » Mon Jun 09, 2025 11:27 am
OverdoneAndDry wrote: Mon Jun 09, 2025 3:10 am Just checking, but is that a separate/alternate database than what "comes with" MakeMKV?
The KEYDB is an independent public database that MakeMKV can fall back upon (if available), should it not find a key within its own private "hashed keys" database. You need to install and update KEYDB yourself, whereas MakeMKV updates its own database automatically.
Post by SamuriHL » Mon Jun 09, 2025 12:39 pm
Right. My utility uses findvuk under the covers to sync the keydb and then copies it to your makemkv data directory automatically to ensure you have the latest keys available.
Sanjuro
Post by Sanjuro » Tue Jun 10, 2025 8:13 pm
Ah I just emailed the dumps for all six of these films without seeing someone had done so yesterday.
But it seems this person only submitted three of the six films so hopefully it was still helpful.
marcdeo
Post by marcdeo » Fri Jun 13, 2025 6:39 pm
Did anybody get the James Bond movies backed up? I can't seem to get it to work on Windows 11...
- It is working, now. Sorry about that...
EvilWarMachine
Post by EvilWarMachine » Tue Jul 01, 2025 8:53 am
The following dump has been submitted to svq@makemkv.com
MKB20_v82_Thunderball_3424
This is from the UK steelbook set
Many thanks!
MrPenguin
Post by MrPenguin » Tue Jul 01, 2025 10:27 am
EvilWarMachine wrote: Tue Jul 01, 2025 8:53 am MKB20_v82_Thunderball_3424
Can you also make this TGZ dump file available here please, e.g. by uploading it into OneDrive or Google Drive and then providing a download link? This could help people add your disk to the public KEYDB.cfg file too.
EvilWarMachine
Post by EvilWarMachine » Tue Jul 01, 2025 11:30 am
MrPenguin wrote: Tue Jul 01, 2025 10:27 am
I don't have those services.
I will attach it here
Edit: It's doesn't seem to be letting me attach them here possibly due to the size
