Unable to Open Bluray Disc - Star Trek Section 31 - AACS v82
cbamatt
#1 Post by cbamatt » Mon Apr 28, 2025 3:44 pm
So I've got Star Trek Section 31 on bluray delivered today, and MakeMKV isn't able to open the disc. I've tried a few things that I found on this forum, but none seem to work.
I've attached the dump that MKV created while trying to open the file.
These are the logs (with debug logging enabled) from MKV):
Debug log started at Mon Apr 28 14:52:13 2025 , written by MakeMKV v1.18.1 win(x64-release)
001005:0000 MakeMKV v1.18.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\matt/MakeMKV_log.txt
No  SDF v098: PIONEER_BD-RW__BDR-XS07U_1.03_CEDL006804WL
DEBUG: Code 0 at \c^YLv PcaLdd\XsJ:29396253
DEBUG: Code 0 at e!/TsMgD>)UEE`0S:213136746
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF id v098: PIONEER_BD-RW__BDR-XS07U_1.03_CEDL006804WL
DEBUG: Code 2147483648 at 2g`y)1d*msr{}#Bb:121265499
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?KPlZ+uzThu9VybVIlPVgtz4/QrAHHEB2roN/j7mDe+msr2MG6sP2NUJHECT2jQ==
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=Pn21XktuNyPYK/LMOgRbK7Vf2gHOlSj9KnNoP6HMw993FHLaW2P7jWNGMGf9Y8Jk3msMWVJNrjJf3NeZ4Zb1ZhE/JyUbuZZQmQyTrz6n8HxtyVczjnj/qiZQAxNTzTHV7iIpfZt5Stqqk8l0/9TUOv0EFySLjOoeGA==
DCE=JybV4qDOo6CRk68Qef8Aat6NRqyPOfiYkRMRnTY1iJPAxKodvKl8xXGQnFJDKucthoWh2jsc2ZN0c+qyxXM+x96Vdi1KecIZimBMqO22hDPmQs+ToqWjc0VyGSp/pudcTaheNMsKZagFjC0FAt3N7ayZjby+PnBlQQ==
003332:0000 Saved AACS dump file as file://C:\Users\matt/.MakeMKV/MKB_v82_Star_Trek-_Section_31_9A9E.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213132721
001003:0020 DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213131341
Application exited at Mon Apr 28 14:55:20 2025
I've then installed the KeyDB Helper tool and ran Synchronize, then Disc Info, then Validate end result is that the "VUK/UnitKeys are invalid". It does tell me to report this in the Doom9 forum with the logfile, but new accounts apparently can't post for 5 days after registering, so posting here also to see if anyone can help here. Full log file also attached.
Is anyone able to provide any help in getting this disc working?
2025-04-28_FindVUK.txt
FindVUK logfile
(344.88 KiB) Downloaded 1702 times
Re: Unable to Open Bluray Disc - Star Trek Section 31 - AACS v82
#2 Post by MartyMcNuts » Tue Apr 29, 2025 12:32 am
cbamatt wrote: Mon Apr 28, 2025 3:44 pm So I've got Star Trek Section 31 on bluray delivered today, and MakeMKV isn't able to open the disc. I've tried a few things that I found on this forum, but none seem to work.
Read your PM.
cbamatt
#3 Post by cbamatt » Tue Apr 29, 2025 9:45 am
That KeyDB addition you sent me worked a treat - thanks!
Supervisor 194
#4 Post by Supervisor 194 » Mon Jun 02, 2025 10:20 am
I've just downloaded the latest version of MakeMKV today, hoping it would be solve the very same Section 31 problem! But I'm still unable to open the Blu-ray or 4K discs due to newer AACS.
Would anyone be able to PM me the appropriate KeyDB along with idiot proof instructions - as I've never come across this issue in years of successfully using the program.
Many thanks.
#5 Post by MartyMcNuts » Tue Jun 03, 2025 12:31 am
Supervisor 194 wrote: Mon Jun 02, 2025 10:20 am I've just downloaded the latest version of MakeMKV today, hoping it would be solve the very same Section 31 problem! But I'm still unable to open the Blu-ray or 4K discs due to newer AACS.
Many thanks.
Did you email the dump file MakeMKV generated to svq@makemkv.com?? You need to do this so the key can be added. You could also attach your dump file here so that we may be able to have the key added to the KeyDB file.
Anne Hathaway
#6 Post by Anne Hathaway » Wed Aug 06, 2025 7:50 am
I have been using MakeMKV since 2016, and I often see that whenever a new movie is released, especially a limited edition or international Blu-ray, it often gets the volume key unknown error as you mentioned. What I usually do is send the dump file directly to Mike (MakeMKV dev) or wait a few days for the database to update. You did the right thing by running KeyDB Helper, but be patient – the problem is not you, it is the new security.
MrPenguin
#7 Post by MrPenguin » Wed Aug 06, 2025 2:30 pm
Supervisor 194 wrote: Mon Jun 02, 2025 10:20 am Would anyone be able to PM me the appropriate KeyDB along with idiot proof instructions - as I've never come across this issue in years of successfully using the program.
If MakeMKV still creates a TGZ dump file after you have installed the latest KEYDB.cfg file, then you will need to email that dump to svq@makemkv.com. And possibly also make that dump available here too please, e.g. by uploading it into (say) OneDrive or Google Drive, and then replying with a public download link.
