Jaws 3 wont rip
xokia
Jaws 3 wont rip
#1 Post by xokia » Sun Jun 01, 2025 2:19 am
I can not get jaws 3 to rip
MrPenguin
Re: Jaws 3 wont rip
#2 Post by MrPenguin » Sun Jun 01, 2025 11:18 am
xokia wrote: Sun Jun 01, 2025 2:19 am I can not get jaws 3 to rip
Have you also emailed this TGZ dump file to svq@makemkv.com? And never mind if you don't, but would you happen to have access to a non-Pioneer UHD drive too please?
xokia
Re: Jaws 3 wont rip
#3 Post by xokia » Sun Jun 01, 2025 4:47 pm
MrPenguin wrote: Sun Jun 01, 2025 11:18 am
Yes I have the LG 16N60 as well. I havent emailed anyone.
MrPenguin
Re: Jaws 3 wont rip
#4 Post by MrPenguin » Sun Jun 01, 2025 5:21 pm
xokia wrote: Sun Jun 01, 2025 4:47 pm Yes I have the LG 16N60 as well. I havent emailed anyone.
You need to email the TGZ dump file to svq@makemkv.com so that your disk can be added to MakeMKV's native "hashed keys" database. This will take an unspecified and unknowable amount of time. However, if you could generate a second TGZ dump file for this disk using your LG drive and provide it here, then The Powers That KEYDB might be able to add your disk to the public KEYDB.cfg file too.
xokia
Re: Jaws 3 wont rip
#5 Post by xokia » Sun Jun 01, 2025 5:56 pm
16N60
I tried
0xC5231FC993A794DD70B60DA18CED34AA0BE018BC = Jaws3_UPK1 (Jaws 3) | D | 2024-05-13
which I found by searching but it did not work
MrPenguin
Re: Jaws 3 wont rip
#6 Post by MrPenguin » Sun Jun 01, 2025 7:05 pm
xokia wrote: Sun Jun 01, 2025 5:56 pm I tried
MakeMKV requires that KEYDB.cfg contains the Volume Unique Key (VUK) for a given disk, so it can only use those entries with a "| V |" field. And besides, KEYDB uses the SHA1 hash of the AACS/Unit_Key_RO.inf file as its key, which for your disk is "0x9C30C57F84E4437A9F64800850F681E754620489" and not "0xC5231FC993A794DD70B60DA18CED34AA0BE018BC " :).
xokia
Re: Jaws 3 wont rip
#7 Post by xokia » Sun Jun 01, 2025 8:24 pm
Sorry I am new to this
I actually do see an entry for
0x9C30C57F84E4437A9F64800850F681E754620489 = Jaws3_UPK1 (Jaws 3) | D | 0000-00-00 | I | 0x53B0DD441AC219623EB96B429A66665A ; MKBv77/BEE (UHD) (LEGACY) (NOTVALIDATED) (BD)
in the keydb.cfg file however it still doe not work is there anything extra I am missing?
I am placing it in C:\Users\<username>\.MakeMKV
Re: Jaws 3 wont rip
#8 Post by SamuriHL » Sun Jun 01, 2025 8:46 pm
Yes, you need to read what he told you more carefully. That entry does not contain a VUK so MakeMKV can't use it. If you want to rip it sooner, you can use something like XReveal which is able to utilize unit keys. Just open the disc in MakeMKV with XReveal open and it should work.
xokia
Re: Jaws 3 wont rip
#9 Post by xokia » Sun Jun 01, 2025 9:43 pm
SamuriHL wrote: Sun Jun 01, 2025 8:46 pm Just open the disc in MakeMKV with XReveal open and it should work.
That does not work either
MrPenguin
Re: Jaws 3 wont rip
#10 Post by MrPenguin » Sun Jun 01, 2025 10:24 pm
xokia wrote: Sun Jun 01, 2025 9:43 pm
Xreveal needs to know the disk's Unit Key, which is the "| U |" field. AFAIK KEYDB does not currently have either a VUK or a Unit Key for your disk. Maybe check back later? SamuriHL also has a utility which may help :).
Re: Jaws 3 wont rip
#11 Post by SamuriHL » Sun Jun 01, 2025 11:10 pm
Oh it's one of those entries with just the VID? I truly hate those. This one will have to wait until someone who can add a full entry can grab it. The unit key was not found.
MrPenguin
Re: Jaws 3 wont rip
#12 Post by MrPenguin » Sun Jun 01, 2025 11:41 pm
SamuriHL wrote: Sun Jun 01, 2025 11:10 pm Oh it's one of those entries with just the VID? I truly hate those.
Actually, it currently has both a VID and a Unit Key. Still no VUK though :(.
Re: Jaws 3 wont rip
#13 Post by SamuriHL » Mon Jun 02, 2025 1:24 am
MrPenguin wrote: Sun Jun 01, 2025 11:41 pm Actually, it currently has both a VID and a Unit Key. Still no VUK though :(.
Do we know if the unit key is correct? I was unable to find one with my methods for that particular disc.
keydb_helper
Re: Jaws 3 wont rip
#14 Post by keydb_helper » Mon Jun 02, 2025 1:52 am
xokia wrote: Sun Jun 01, 2025 5:56 pm 16N60
I tried
Thanks for providing a suitable disc dump file. The 491C variant of Jaws 3 now has a complete record in the public keydb so it should allow MakeMKV to decrypt your particular disc.
Public KeyDB Disc Submissions
xokia
Re: Jaws 3 wont rip
#15 Post by xokia » Tue Jun 03, 2025 5:48 pm
keydb_helper wrote: Mon Jun 02, 2025 1:52 am Thanks for providing a suitable disc dump file. The 491C variant of Jaws 3 now has a complete record in the public keydb so it should allow MakeMKV to decrypt your particular disc.
That worked thank you!
