Jaws 3 wont rip
Re: Jaws 3 wont rip
Have you also emailed this TGZ dump file to svq@makemkv.com? And never mind if you don't, but would you happen to have access to a non-Pioneer UHD drive too please?
Re: Jaws 3 wont rip
Yes I have the LG 16N60 as well. I havent emailed anyone.MrPenguin wrote: Sun Jun 01, 2025 11:18 amHave you also emailed this TGZ dump file to svq@makemkv.com? And never mind if you don't, but would you happen to have access to a non-Pioneer UHD drive too please?
Re: Jaws 3 wont rip
You need to email the TGZ dump file to svq@makemkv.com so that your disk can be added to MakeMKV's native "hashed keys" database. This will take an unspecified and unknowable amount of time. However, if you could generate a second TGZ dump file for this disk using your LG drive and provide it here, then The Powers That KEYDB might be able to add your disk to the public KEYDB.cfg file too.
Re: Jaws 3 wont rip
16N60
I tried
0xC5231FC993A794DD70B60DA18CED34AA0BE018BC = Jaws3_UPK1 (Jaws 3) | D | 2024-05-13
which I found by searching but it did not work
I tried
Re: Jaws 3 wont rip
MakeMKV requires that KEYDB.cfg contains the Volume Unique Key (VUK) for a given disk, so it can only use those entries with a "| V |" field. And besides, KEYDB uses the SHA1 hash of the AACS/Unit_Key_RO.inf file as its key, which for your disk is "0x9C30C57F84E4437A9F64800850F681E754620489" and not "0xC5231FC993A794DD70B60DA18CED34AA0BE018BC "xokia wrote: Sun Jun 01, 2025 5:56 pm I tried
Re: Jaws 3 wont rip
Sorry I am new to this
I actually do see an entry for
0x9C30C57F84E4437A9F64800850F681E754620489 = Jaws3_UPK1 (Jaws 3) | D | 0000-00-00 | I | 0x53B0DD441AC219623EB96B429A66665A ; MKBv77/BEE (UHD) (LEGACY) (NOTVALIDATED) (BD)
in the keydb.cfg file however it still doe not work is there anything extra I am missing?
I am placing it in C:\Users\<username>\.MakeMKV
Re: Jaws 3 wont rip
Yes, you need to read what he told you more carefully. That entry does not contain a VUK so MakeMKV can't use it. If you want to rip it sooner, you can use something like XReveal which is able to utilize unit keys. Just open the disc in MakeMKV with XReveal open and it should work.
Re: Jaws 3 wont rip
That does not work eitherSamuriHL wrote: Sun Jun 01, 2025 8:46 pm Just open the disc in MakeMKV with XReveal open and it should work.
Re: Jaws 3 wont rip
Xreveal needs to know the disk's Unit Key, which is the "| U |" field. AFAIK KEYDB does not currently have either a VUK or a Unit Key for your disk. Maybe check back later? SamuriHL also has a utility which may help
Re: Jaws 3 wont rip
Oh it's one of those entries with just the VID? I truly hate those. This one will have to wait until someone who can add a full entry can grab it. The unit key was not found.
Re: Jaws 3 wont rip
Actually, it currently has both a VID and a Unit Key. Still no VUK thoughSamuriHL wrote: Sun Jun 01, 2025 11:10 pm Oh it's one of those entries with just the VID? I truly hate those.
Re: Jaws 3 wont rip
Do we know if the unit key is correct? I was unable to find one with my methods for that particular disc.MrPenguin wrote: Sun Jun 01, 2025 11:41 pm Actually, it currently has both a VID and a Unit Key. Still no VUK though.
keydb_helper
Re: Jaws 3 wont rip
Thanks for providing a suitable disc dump file. The 491C variant of Jaws 3 now has a complete record in the public keydb so it should allow MakeMKV to decrypt your particular disc.xokia wrote: Sun Jun 01, 2025 5:56 pm 16N60
I tried
Public KeyDB Disc Submissions
Re: Jaws 3 wont rip
That worked thank you!keydb_helper wrote: Mon Jun 02, 2025 1:52 am Thanks for providing a suitable disc dump file. The 491C variant of Jaws 3 now has a complete record in the public keydb so it should allow MakeMKV to decrypt your particular disc.
