2001: A Space Oddyssey Dump Submitted
AnBird
#1 Post by AnBird » Tue Oct 22, 2024 6:26 am
Dump submitted for the following disc:
MKB20_v66_2001-_A_Space_Odyssey_F033
At time of writing, most recent keydb has a key for this disc.
CalicoSkies
Re: 2001: A Space Oddyssey Dump Submitted
#2 Post by CalicoSkies » Wed Oct 23, 2024 3:47 pm
Which version/release is this for? I bought this movie on 4K blu-ray years ago and was already able to rip it with MakeMKV.
#3 Post by dcoke22 » Wed Oct 23, 2024 4:26 pm
CalicoSkies wrote: Wed Oct 23, 2024 3:47 pm Which version/release is this for? I bought this movie on 4K blu-ray years ago and was already able to rip it with MakeMKV.
It isn't uncommon for new pressings of the same title/release to need a new hashed key. High profile releases often need several different hashed keys in their initial run of discs.
kolace
#4 Post by kolace » Fri May 30, 2025 11:58 pm
edit: never mind, the latest keydb.cfg file worked, but I had to close *all* instances of MakeMKV to get it to recognize it, not just the one I was using.
I just submitted a dump with the same name. Not sure why it's not working but hopefully the new dump will help! I tried putting the latest KEYDB.cfg file in the MakeMKV data folder also and that didn't help.
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-UD04 1.14 DBDL132872WLd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Backing up disc into folder "/Users/blah/Movies/backup/2001_ A Space Odyssey"
Saved AACS dump file as /Users/blah/Library/MakeMKV/MKB20_v66_2001_A_Space_Odyssey_F033.tgz
Backup failed
MrPenguin
#5 Post by MrPenguin » Sat May 31, 2025 3:50 pm
kolace wrote: Fri May 30, 2025 11:58 pm Saved AACS dump file as /Users/blah/Library/MakeMKV/MKB20_v66_2001_A_Space_Odyssey_F033.tgz
If the latest KEYDB.cfg file doesn't work, could you provide your TGZ dump file here please, either as an attachment or via a download link?
kolace
#6 Post by kolace » Sat May 31, 2025 4:42 pm
MrPenguin wrote: Sat May 31, 2025 3:50 pm
It does work actually, turns out I needed to close all instances of MakeMKV to get it to load the file, not just the one I was using to rip the disk. Thanks though!
