Bill & Ted's Excellent Adventure UHD Dump
trickeyone
Post by trickeyone » Fri May 30, 2025 6:39 am
Submitted today.
MKB20_v76_BILL_TEDS_EXCELLENT_ADVENTURE_7087.tgz
MrPenguin
Re: Bill & Ted's Excellent Adventure UHD Dump
Post by MrPenguin » Fri May 30, 2025 1:54 pm
trickeyone wrote: Fri May 30, 2025 6:39 am MKB20_v76_BILL_TEDS_EXCELLENT_ADVENTURE_7087.tgz
FWIW could you also upload the AACS/MKB_RO.inf file from your physical UHD disk here, please? (It's a large file, so you'll need to ZIP compress it first.) The copy of MKB_RO.inf inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself.
You might also find SamuriHL's tool useful :).
trickeyone
Post by trickeyone » Fri May 30, 2025 6:30 pm
Yes, I downloaded the latest before submitting the dump. Even with the latest keysdb, it couldn't decrypt the disc
trickeyone
Post by trickeyone » Fri May 30, 2025 6:38 pm
MrPenguin wrote: Fri May 30, 2025 1:54 pm
I have the keysdb.cfg in
C:\ProgramData\aacs
. There is no data directory in the
.MakeMKV
directory where it creates the dumps. Do I need to create the directory, and is it just "data"?
MK_RO.inf file attached
MrPenguin
Post by MrPenguin » Sat May 31, 2025 11:40 am
trickeyone wrote: Fri May 30, 2025 6:38 pm I have the keysdb.cfg in
C:\ProgramData\aacs
.MakeMKV
Just copy the KEYDB.cfg file into your
.MakeMKV/
directory.
MakeMKV's data directory is not literally called "data" unless you explicitly configure MakeMKV via its "View/Preferences/General" settings.
AFAICT KEYDB.cfg already contains your disk's key, and so MakeMKV should be able to decrypt it.
trickeyone
Post by trickeyone » Sun Jun 01, 2025 3:25 am
Ah, ok. I'll try that. What's weird is that it decrypted the other 2 UHD's in the set. It's the new box set that came out recently with all 3 movies.
