Wan Pipel Cult Epics BD (2025) Issue
KimJongNumberUn
#1 Post by KimJongNumberUn » Thu May 29, 2025 5:19 pm
So I can't even get this one to show up on my computer BD drive, let alone get MakeMKV detect it. It's not a defective disc because it plays on a regular Blu-Ray player. And the drive isn't broken because all other discs play. Is there some newer copy protection on it?
https://www.cultepics.com/product-detail/wan-pipel/
MrPenguin
Re: Wan Pipel Cult Epics BD (2025) Issue
#2 Post by MrPenguin » Thu May 29, 2025 7:35 pm
KimJongNumberUn wrote: Thu May 29, 2025 5:19 pm So I can't even get this one to show up on my computer BD drive, let alone get MakeMKV detect it. It's not a defective disc because it plays on a regular Blu-Ray player. And the drive isn't broken because all other discs play. Is there some newer copy protection on it?
If this disk plays in a regular BluRay player then it sounds like a regular BluRay to me. Did MakeMKV generate a TGZ dump file for it? And if so, can you provide that dump here please?
#3 Post by dcoke22 » Sat May 31, 2025 5:33 pm
It might just need a gentle cleaning. Sometimes new discs can have left over lubricants from the manufacturing process or deposits from the plastic case off gassing. I gently clean discs with liquid dish soap, plenty of warm water, and light pressure from my fingertip. A light scrubbing, a thorough rise, and a good drying (really be sure the disc is dry; you don't want to spray the inside of your drive with water when the disc spins) often help.
