MKB20_v77_What_Lies_Beneath_8C52.tgz
Submitted it to svq.
Bit weird as it seems to be in keydb.cfg already. But for some reason, it can't be decrypted.
P.S.: first post, yay! Tons of useful information here in the forum, helped me a lot.
Dump submitted - What Lies Beneath 4k
MarleneMuses
- MKB20_v77_What_Lies_Beneath_8C52.tgz
- (3.31 MiB) Downloaded 144 times
Re: Dump submitted - What Lies Beneath 4k
That would usually suggest that the entry in KEYDB.cfg does not contain a "| V |" field, i.e. the disk's Volume Unique Key (VUK). Would you happen to have access to a non-Pioneer UHD drive please? Perhaps that would allow The Powers That KEYDB to help further?MarleneMuses wrote: Thu May 29, 2025 1:36 pm Bit weird as it seems to be in keydb.cfg already. But for some reason, it can't be decrypted.
You might also find SamuriHL's tool useful
MarleneMuses
No, I only have 2 Pioneer drives, one of them not LibreDrive ready.MrPenguin wrote: Thu May 29, 2025 4:56 pm That would usually suggest that the entry in KEYDB.cfg does not contain a "| V |" field, i.e. the disk's Volume Unique Key (VUK). Would you happen to have access to a non-Pioneer UHD drive please? Perhaps that would allow The Powers That KEYDB to help further?
OK fair enough. If you're a Windows user then you might be able to use Xreveal with KEYDB.cfg to decrypt your disk. The alternative would be either waiting for someone else to provide the missing information, or waiting for MakeMKV to process your dump file.MarleneMuses wrote: Thu May 29, 2025 5:25 pm No, I only have 2 Pioneer drives, one of them not LibreDrive ready.
It's also possible that your second Pioneer might start supporting LibreDrive, but I would definitely expect one of the other two alternatives to happen first
