Dump submitted - What Lies Beneath 4k
MarleneMuses
Post by MarleneMuses »
MKB20_v77_What_Lies_Beneath_8C52.tgz
Submitted it to svq.
Bit weird as it seems to be in keydb.cfg already. But for some reason, it can't be decrypted.
P.S.: first post, yay! Tons of useful information here in the forum, helped me a lot.
(3.31 MiB) Downloaded 141 times
MrPenguin
Re: Dump submitted - What Lies Beneath 4k
Post by MrPenguin »
MarleneMuses wrote: Thu May 29, 2025 1:36 pm Bit weird as it seems to be in keydb.cfg already. But for some reason, it can't be decrypted.
That would usually suggest that the entry in KEYDB.cfg does not contain a "| V |" field, i.e. the disk's Volume Unique Key (VUK). Would you happen to have access to a non-Pioneer UHD drive please? Perhaps that would allow The Powers That KEYDB to help further?
You might also find SamuriHL's tool useful :).
MarleneMuses
MrPenguin wrote: Thu May 29, 2025 4:56 pm That would usually suggest that the entry in KEYDB.cfg does not contain a "| V |" field, i.e. the disk's Volume Unique Key (VUK). Would you happen to have access to a non-Pioneer UHD drive please? Perhaps that would allow The Powers That KEYDB to help further?
No, I only have 2 Pioneer drives, one of them not LibreDrive ready.
MrPenguin
Post by MrPenguin »
MarleneMuses wrote: Thu May 29, 2025 5:25 pm No, I only have 2 Pioneer drives, one of them not LibreDrive ready.
OK fair enough. If you're a Windows user then you might be able to use Xreveal with KEYDB.cfg to decrypt your disk. The alternative would be either waiting for someone else to provide the missing information, or waiting for MakeMKV to process your dump file.
It's also possible that your second Pioneer might start supporting LibreDrive, but I would definitely expect one of the other two alternatives to happen first ;).
