Yellowstone Season 5 Part 2 (US) Dump Files
rmalay
#1 Post by rmalay » Tue May 27, 2025 11:08 pm
Discs 1,2,3
MKB_v82_Yellowstone-_Season_5,_Part_2_-_Disc_3_9FD8.tgz
MKB_v82_Yellowstone-_Season_5,_Part_2_-_Disc_2_26A4.tgz
MKB_v82_Yellowstone-_Season_5,_Part_2_-_Disc_1_4D38.tgz
MrPenguin
Re: Yellowstone Season 5 Part 2 (US) Dump Files
#2 Post by MrPenguin » Tue May 27, 2025 11:30 pm
Discs 1,2,3
MarkV
#3 Post by MarkV » Wed May 28, 2025 12:54 pm
This worked for me.
DowntownAB
#4 Post by DowntownAB » Wed May 28, 2025 5:54 pm
Hello. This is for MrPenguin or anyone else who can answer. I want to try the solution for Yellowstone Season 5 Part Two that MrPenguin mentioned in this thread. I downloaded the KEYDB.cfg file
(which shows up as "keydb.cfg 2", a 57.9 MB document after opening the zip - is this right?). I'm not sure how to copy it into MAKEMKV's data directory. How can I get to the data directory? Do I just drag and drop the file anywhere in there once I find it?
#5 Post by SamuriHL » Wed May 28, 2025 6:14 pm
I'm not sure what the 2 is on that. It needs to be named exactly KEYDB.cfg. The MakeMKV data directory is where your dump files are created. You can find it by going to MakeMKV, preferences, general tab. You'll see the data directory listed there.
Alternatively if you're on Windows, my tool can be of assistance with all this.
viewtopic.php?f=12&t=16883&p=166510#p166510
Make sure to read through the post thoroughly as it might help you more than you realize if you do. ;)
DowntownAB
#6 Post by DowntownAB » Wed May 28, 2025 6:58 pm
SamuriHL, thank you very much. I have a Mac. I changed the file name to not have the "2" in it, and then dragged it into the MakeMKV data directory (which is the default folder in my Mac's hard drive called "movies", under my name as user). I restarted MakeMKV and the content seems to be ripping fine. Appreciate your help, along with MrPenguin. Cheers.
Tankerhank
#7 Post by Tankerhank » Fri May 30, 2025 2:51 pm
Discs 1,2,3
This worked, I just did the above. MKV is currently running disk 1 of Season 5 part 2
Willy6560
#8 Post by Willy6560 » Fri May 30, 2025 5:49 pm
I tried putting KEYDB.cfg into my "C:\Users\bill\.MakeMKV" folder (where the tgz files are written), but I'm still not able to get Yellowstone to decript. Also, the KEYDB.cfg file is from a UK source. I live in the US, so is this UK version supposed to work for me? I also tried to do this on two different BD drive, with the same result. Thanks, Bill
BTW, would it help for me to upload my three tgz files here?
Here's my status/error results if this helps.
Product: BD-RE WH16NS40
Revision: 1.04
Serial number: KLEJ7UF3301
Firmware date: 2119-01-04 13:48
Highest AACS version: 82
Disc Information
Label: Yellowstone_Season5_Part2
Timestamp: 2025-03-19 15:25:22
Protection: AACS v82
Data capacity: 41.43 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.18.1 win(x64-release) started
Saved FW dump file as C:\Users\bill/.MakeMKV/dump_FW_1695CFC5DF96FD19C159.tgz
Please send the file "C:\Users\bill/.MakeMKV/dump_FW_1695CFC5DF96FD19C159.tgz" to support@makemkv.com
Backing up disc into folder "D:/MakeMKV/backup/Yellowstone_Season5_Part2"
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?GjPfVCSeU2rxyh...
Saved AACS dump file as C:\Users\bill/.MakeMKV/MKB_v82_Yellowstone_Season5_Part2_4D38.tgz
Backup failed
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?/ASnrXnjzFCuoX...
Saved AACS dump file as C:\Users\bill/.MakeMKV/MKB_v82_Yellowstone_Season5_Part2_26A4.tgz
Backup failed
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?N4wFF6h2IpPj4k...
Saved AACS dump file as C:\Users\bill/.MakeMKV/MKB_v82_Yellowstone_Season5_Part2_9FD8.tgz
Backup failed
jrogers
#9 Post by jrogers » Sat May 31, 2025 2:53 pm
Is this something that will eventually work on its own without having to go through these hoops?
#10 Post by dcoke22 » Sat May 31, 2025 3:46 pm
If someone emails the dump files to svq@makemkv.com then eventually MakeMKV will download the necessary bits in the background and it'll just work.
MrPenguin
#11 Post by MrPenguin » Sat May 31, 2025 3:47 pm
You appear to have the exact same disks as the OP, in which case (AFAIK) the latest KEYDB.cfg file should already contain your keys.
Willy6560
#12 Post by Willy6560 » Sun Jun 01, 2025 6:21 pm
I got it to work. Thanks for all the info on the KEYDB.cfg file. On initial installation, the KEYDB.cfg file was placed in the default "C:\Users\bill\.MakeMKV" folder. However, I changed the default directory to a different drive. Once I figured out that the original C: drive folder was no longer used, I copied the KEYDB.cfg file to the new drive/folder and it worked.
