- 88 Films "Hell of the Living Dead" 4K UHD
Scream Factory "John Carpenter's Vampires" 4K UHD
Kino Lorber "Stephen King's Graveyard Shift" 4K UHD
Criterion Collection "Godzilla vs. Biollante" 4K UHD
Severin's "Rats Night of Terror" 4K UHD
Vinegar Syndrome's "Brimstone & Treacle" 4K UHD
Universal's "Nosferatu (2024)" 4K UHD
Blue Underground's "Venom" 4K UHD
Paramount's "Smile 2" 4K UHD
New user trying to decrypt a number of 4K UHD blurays, all give "unknown volume key"
I have reported all of these to "svq@makemkv.com". However, it's suspicious that none of these worked. They're a cross-section of mainstream and more "boutique" titles across a variety of vendors:
Re: New user trying to decrypt a number of 4K UHD blurays, all give "unknown volume key"
Update: I finally found a UHD disc that worked. I was able to successfully rip Sony/Columbia Picture's "2012" UHD blu-ray. So I guess it must be pretty commonplace that movies' keys are not yet available. Hopefully in a few days the titles below will work as well?
Yes, but all you need to do is email the TGZ dump file that MakeMKV creates to svq@makemkv.com and then wait for its key to be generated. While you're waiting, you can also try posting those same TGZ dump files here so that The Powers That KEYDB can examine them too.lonnym wrote: ↑Sun May 18, 2025 8:26 pmUpdate: I finally found a UHD disc that worked. I was able to successfully rip Sony/Columbia Picture's "2012" UHD blu-ray. So I guess it must be pretty commonplace that movies' keys are not yet available. Hopefully in a few days the titles below will work as well?
You can download the KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV. This will allow MakeMKV to use your KEYDB.cfg file as a "fallback" database.
OK, here are the first 3 TGZ files...
MKB20_v77_Graveyard_Shift_C6A3.tgz
MKB20_v77_GODZILLA_VS_BIOLLANTE_AB01.tgz
MKB20_v76_Hell_Of_The_Living_Dead_EE81.tgz
...here are the next batch of 3...
MKB20_v77_RATS_NIGHT_OF_TERROR_UHD_0EE3.tgz
MKB20_v77_Nosferatu_EF45.tgz
MKB20_v77_John_Carpenter's_Vampires_95DB.tgz
...and here's the final batch of 3...
MKB20_v77_VS497UHD_882B.tgz
MKB20_v77_VENOM_D16B.tgz
MKB20_v77_Smile_2_129B.tgz
7 of your 9 titles are already supported by the public keydb. Until MakeMKV supports your discs natively you can backup your discs by following my instructions here or using SamuriHL's utility for Windows (Link)lonnym wrote: ↑Sun May 18, 2025 4:26 pmI have reported all of these to "svq@makemkv.com". However, it's suspicious that none of these worked. They're a cross-section of mainstream and more "boutique" titles across a variety of vendors:I believe I have the firmware flashed properly for my LG BP50NB40 (firmware is BP60NB10 1.00). Everything looks like it's working correctly, but I didn't expect to encounter "unknown volume key" for _every_ disc I tried.
Your two problematic titles are MKB20_v77_VENOM_D16B and MKB20_v77_RATS_NIGHT_OF_TERROR_UHD_0EE3. Could you please zip and attach the MKB_RO.inf files from these two discs to the forum? You'll find this file in the AACS folder on each disc and it is a distinct file for each title.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
