Hi, I bought the Japanese Blu-ray for Moana 2 in April and I've been trying to rip it, but have been having no luck. I've been the "volume key is unknown" error and I think it's because it's newer. I've attached the files from the 4k and BD.
Thank you for your help!
MKB20_v77_MOANA_2_2C99.tgz.gz
MKB_v82_MOANA_2_-_BLU-RAY_1280.tgz.gz
MKB_v82_MOANA_2_1280.tgz.gz
Moana 2 Japanese 4k & BD
Re: Moana 2 Japanese 4k & BD
Read your PM.SM2022 wrote: Mon May 19, 2025 4:25 am Hi, I bought the Japanese Blu-ray for Moana 2 in April and I've been trying to rip it, but have been having no luck. I've been the "volume key is unknown" error and I think it's because it's newer. I've attached the files from the 4k and BD.
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?SM2022 wrote: Mon May 19, 2025 4:25 am Hi, I bought the Japanese Blu-ray for Moana 2 in April and I've been trying to rip it, but have been having no luck. I've been the "volume key is unknown" error and I think it's because it's newer. I've attached the files from the 4k and BD.
SM2022
That worked. Thank you!MrPenguin wrote: Mon May 19, 2025 10:57 amHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?SM2022 wrote: Mon May 19, 2025 4:25 am Hi, I bought the Japanese Blu-ray for Moana 2 in April and I've been trying to rip it, but have been having no luck. I've been the "volume key is unknown" error and I think it's because it's newer. I've attached the files from the 4k and BD.
