BU40N firmware flash
LogiX
Post by LogiX » Thu May 15, 2025 6:07 pm
Hello everyone,
my Verbatim 43888 arrived today. Unfortunately I got the LG BU40N. Here is the data:
Drive Information:
OS device name: G:
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.05
Serial number: xxx
how do i flash the drive so that i can rip 4k bluerays etc.?
Can you help me?
Re: BU40N firmware flash
Post by MartyMcNuts » Fri May 16, 2025 12:00 am
LogiX wrote: Thu May 15, 2025 6:07 pm Hello everyone,
Drive Information:
OS device name: G:
Revision: 1.05
Serial number: xxx
Can you help me?
Try reading the Ultimate UHD drive guide 2025
DavoBR
Post by DavoBR » Fri May 16, 2025 5:45 am
Drive Information:
OS device name: G:
Revision: 1.05
Serial number: xxx
Can you help me?
Same happened for me. I got two 43888 drives. The first drive was a Pioneer, the second LG.
Make sure you thoroughly read the flashing guide (viewtopic.php?f=16&t=19634) and, when you're finished, read it again.
Basically, you want Marty's GUI SDF tool (viewtopic.php?f=16&t=22896)... note that the links for the later versions do not work for me and I had to download and use the 'old original' SDFtool flasher.
Download the 'All you need firmware pack'
Unzip and put all files into the same folder
Plug in the drive, run the tool, select the BU40N firmware file, tick Enc and click on the relevant button to proceed.
Pretty straightforward.
MrPenguin
Post by MrPenguin » Fri May 16, 2025 11:02 am
DavoBR wrote: Fri May 16, 2025 5:45 am Same happened for me. I got two 43888 drives. The first drive was a Pioneer, the second LG.
To be fair, TGZ dump files produced by the LG drive will be far more useful to The Powers That KEYDB ;).
office_icarus
Post by office_icarus » Mon Apr 27, 2026 2:36 am
LogiX wrote: Thu May 15, 2025 6:07 pm my Verbatim 43888 arrived today. Unfortunately I got the LG BU40N. Here is the data:
Drive Information:
OS device name: G:
Revision: 1.05
Serial number: xxx
Fantastic assist. Same ODD/specs as Op [with ICY DOCK MB343SPO FLEX-FIT Duo; c/o Billy] -- following your abbreviated notes did the trick for me! [e.g. utilizing retired SDFtool Flasher 1.2.0]
obliged!
DavoBR
Post by DavoBR » Mon Apr 27, 2026 9:30 am
office_icarus wrote: Mon Apr 27, 2026 2:36 am
Drive Information:
obliged!
:D
