Dear MakeMKV Support and Community,
I encountered an issue while trying to back up a Blu-ray disc using MakeMKV v1.18.1 on macOS. This is the first time I’ve run into this particular problem — the disc appears to use a newer AACS version (v82), and the volume key isn’t available in the current key database.
Disc Information
Disc Label: TCAB_271A
AACS Version: v82
Drive Model: MATSHITA BD-CMB UJ135AS 1.01 (MacBook Air internal drive)
MakeMKV Log Snippet:
swift
This disc uses newer version of AACS protection.
Saved AACS dump file: /Users/asuka/Library/MakeMKV/MKB_v82_TCAB_271A_5E72.tgz
What I’ve Done So Far
I saved the AACS dump file as prompted by MakeMKV.
Uploaded the dump via this link.
(Optional) Attached full log file if needed.
Request
Would it be possible to add the volume key for this disc (TCAB_271A) to the public KEYDB.cfg?
Also, I’d appreciate it if I could be notified once the key becomes available or if there's a workaround in the meantime.
Thanks again to the MakeMKV team and community for your continued support!
Best regards,
LEE
TCAB_271A Blu-ray: AACS v82 – Volume key missing
- MKB_v82_TCAB_271A_5E72.tgz
- (105.41 KiB) Downloaded 436 times
Re: TCAB_271A Blu-ray: AACS v82 – Volume key missing
Read your PM.leekim wrote: ↑Wed May 14, 2025 2:04 amDear MakeMKV Support and Community,
Disc Information
AACS Version: v82
swift
Request
Best regards,
LEE
Thank you very much for your assistance. I was able to successfully open TCAB_271A.
However, I'm currently having trouble accessing TCAB_271B, as it cannot be opened at this time.
If it's not too much trouble, could you kindly provide the relevant KeyDB information for TCAB_271B as well?
I truly appreciate your continued support and assistance.
- MKB_v82_unkn0wn_AF14.tgz
- (100.81 KiB) Downloaded 357 times
This dump file looks incorrect:leekim wrote: ↑Thu May 15, 2025 4:18 pmThank you very much for your assistance. I was able to successfully open TCAB_271A.
003006:0000 Opening files on harddrive at file:///Volumes/TCAB_271B
