Landman Season 1 Blu-Ray: Failed to open disc
chucky527c
Post by chucky527c »
First time that I've had a Blu Ray disc not decrypt using MakeMKV. Currently running MakeMKV v 1.18.1
It says "This disc uses newer version of AACS protection" on disc 1. I can attach dump files if helpful. Otherwise, any ideas?
shibish
Re: Landman Season 1 Blu-Ray: Failed to open disc
Post by shibish »
same issue here
chucky527c wrote: Tue May 13, 2025 10:58 pm First time that I've had a Blu Ray disc not decrypt using MakeMKV. Currently running MakeMKV v 1.18.1
You should email that dump file to svq@makemkv.com for processing.
You can also attach the dump file here and we might be able to add it to the KeyDB file too.
chucky527c
MartyMcNuts wrote: Tue May 13, 2025 11:20 pm
I wasn't sure if the etiquette rules were different in this forum vs the UHD discs forum. I have submitted to svq and attached here.
chucky527c wrote: Tue May 13, 2025 11:38 pm
Please read your PM.
phaelix
Post by phaelix »
I am encountering the same issue with "This disc uses newer version of AACS protection", has anyone found a solution to this?
MrPenguin
Post by MrPenguin »
phaelix wrote: Sun May 18, 2025 5:29 am I am encountering the same issue with "This disc uses newer version of AACS protection", has anyone found a solution to this?
Yes, you should email your TGZ dump files to svq@makemkv.com, and then wait patiently.
While you are waiting, you can also try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV. And if even that doesn't help, then maybe provide your TGZ dump files here too as attachments?
BTW if the names of your TGZ dump files are identical to those one attached earlier and you still cannot decrypt, then you have probably copied your KEYDB.cfg file into the wrong directory :).
