Dump Submitted for:
Mickey 17 (2025) | Warner Bros. (2025)
MKB20_v77_Mickey_17_099E.tzg
Tuesday, May 13, 2025 @ 5:09 PM EDT
Submitted via email to:
svq@makemkv.com
Dump Submitted - Mickey 17 (2025) | Warner Bros. 2025
kfscoll
MrPenguin
Re: Dump Submitted - Mickey 17 (2025) | Warner Bros. 2025
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e.where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
kfscoll
I sure have - no joy.
MrPenguin
I'm fairly sure this KEYDB entry matches your disk:
0xC8E0CC846CAEDA73B9D4739CE3B4E3FB5B05307A = MICKEY_17 (Mickey 17) | D | 2025-03-04 | ... -
Monkeylord
Just submitted this, UK UHD release.
MKB20_v77_Mickey_17_ADE6
Monkeylord
This one is now working via the KEYDB.cfg method. Currently ripping a copy as we speak.Monkeylord wrote: Mon May 26, 2025 3:30 pm Just submitted this, UK UHD release.
murx75
Here is a new dump for Mickey 17, will submit it soon:
MKB20_v77_MICKEY_17_D63A.tgz
https://www.mediafire.com/file/4jv0szok ... A.tgz/file
Cheers!
Cheers!
keydb_helper
Thanks for providing a suitable disc dump file. The D63A variant of Mickey 17 has been added to the public keydb.murx75 wrote: Fri May 30, 2025 3:04 pm Here is a new dump for Mickey 17, will submit it soon:
Cheers!
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
murx75
Thank you so much! Backing up my D63A disc now.
