Dump Submitted - Mickey 17 (2025) | Warner Bros. 2025
kfscoll
Post by kfscoll »
Dump Submitted for:
Mickey 17 (2025) | Warner Bros. (2025)
MKB20_v77_Mickey_17_099E.tzg
Tuesday, May 13, 2025 @ 5:09 PM EDT
Submitted via email to:
svq@makemkv.com
MrPenguin
Re: Dump Submitted - Mickey 17 (2025) | Warner Bros. 2025
Post by MrPenguin »
kfscoll wrote:
Tue May 13, 2025 9:10 pm
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e.where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
kfscoll
Post by kfscoll »
MrPenguin wrote:
Tue May 13, 2025 9:14 pm
I sure have - no joy.
MrPenguin
Post by MrPenguin »
kfscoll wrote:
Tue May 13, 2025 11:26 pm
I'm fairly sure this KEYDB entry matches your disk:
0xC8E0CC846CAEDA73B9D4739CE3B4E3FB5B05307A = MICKEY_17 (Mickey 17) | D | 2025-03-04 | ...
And since it includes a Volume Unique Key (VUK), MakeMKV can use it to decrypt your disk.
Monkeylord
Post by Monkeylord »
Just submitted this, UK UHD release.
MKB20_v77_Mickey_17_ADE6
Monkeylord
Monkeylord wrote:
Mon May 26, 2025 3:30 pm
This one is now working via the KEYDB.cfg method. Currently ripping a copy as we speak.
murx75
Post by murx75 »
Here is a new dump for Mickey 17, will submit it soon:
MKB20_v77_MICKEY_17_D63A.tgz
https://www.mediafire.com/file/4jv0szok ... A.tgz/file
Cheers!
keydb_helper
Post by keydb_helper »
murx75 wrote:
Fri May 30, 2025 3:04 pm
Cheers!
Thanks for providing a suitable disc dump file. The D63A variant of Mickey 17 has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
murx75
Post by murx75 »
Thank you so much! Backing up my D63A disc now.
