Key Add - Tunnel To Summer
Fu2chN
Post by Fu2chN »
Hi, I submitted Tunnel To Summer
MKB_v82_TUNNEL_TO_SUMMER_2C04.tgz
It's work Now.
Re: Dump Submitted - Tunnel To Summer
Fu2chN wrote: Sun May 11, 2025 7:40 am Hi, I submitted Tunnel To Summer
If you also upload your dump file here, we may be able to add your disc to the KeyDB database.
MrPenguin
Post by MrPenguin »
Fu2chN wrote: Sun May 11, 2025 7:40 am MKB_v82_TUNNEL_TO_SUMMER_2C04.tgz
The KEYDB.cfg file already contains this entry:
0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 = TUNNEL_TO_SUMMER (TUNNEL TO SUMMER) | D | 2025-03-11 | ...
Does this match your disk? And if so, could you maybe execute
findvuk valdiateDisc drive=<your-UHD-drive-letter>
for this entry please :)?
Fu2chN
Post by Fu2chN »
My laste keydb date is 09/05/2025
I update manualy to 11/05/2025 23:53
It's work now. But I still have this message:
"Ce disque utilise une version plus récente de protection AACS. Merci de nous en informer en visitant http://www.makemkv.com/a/?X2e4GghI5xlANP..."
MrPenguin
Post by MrPenguin »
Fu2chN wrote: Sun May 11, 2025 9:57 pm My laste keydb date is 09/05/2025
It sounds as if MakeMKV doesn't have this disk's key yet, but that KEYDB does. However, I also think KEYDB has contained an entry for
since before 9th May 2025.
Fu2chN
Re: Key Add - Tunnel To Summer
Post by Fu2chN »
Maybe US disc, I have the french disc release 07/05/2025
MrPenguin
Post by MrPenguin »
Fu2chN wrote: Sun May 11, 2025 10:46 pm Maybe US disc, I have the french disc release 07/05/2025
The MakeMKV variant of DiscID=0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 is 2C04.
What is your DiscID please, i.e. the SHA1 hash of the AACS/Unit_Key_RO.inf file?
Can you attach your dump file here. We can confirm or add your disc's key if not in the keyDB database.
Fu2chN
Post by Fu2chN »
Here is the dump.
I remind you that now it passes, apart from the AACS message, everything is ok.
Fu2chN wrote: Mon May 12, 2025 4:27 am Here is the dump.
You shouldn't get that message if everything is working correctly! Are you using the latest version (v1.18.1) of MakeMKV?
Yes, I can confirm that the existing KeyDB entry for disc ID: 0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 is correct and is the same as Fu2chN's disc.
Fu2chN
Post by Fu2chN »
MartyMcNuts wrote: Mon May 12, 2025 5:32 am
yes I use the latest version of MakeMKV.
