Key Add - Tunnel To Summer
Fu2chN
Hi, I submitted Tunnel To Summer
MKB_v82_TUNNEL_TO_SUMMER_2C04.tgz
It's work Now.
It's work Now.
Re: Dump Submitted - Tunnel To Summer
If you also upload your dump file here, we may be able to add your disc to the KeyDB database.Fu2chN wrote: Sun May 11, 2025 7:40 am Hi, I submitted Tunnel To Summer
MrPenguin
The KEYDB.cfg file already contains this entry:
0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 = TUNNEL_TO_SUMMER (TUNNEL TO SUMMER) | D | 2025-03-11 | ...Code: Select all
findvuk valdiateDisc drive=<your-UHD-drive-letter>-
Fu2chN
My laste keydb date is 09/05/2025
I update manualy to 11/05/2025 23:53
It's work now. But I still have this message:
"Ce disque utilise une version plus récente de protection AACS. Merci de nous en informer en visitant http://www.makemkv.com/a/?X2e4GghI5xlANP..."
MrPenguin
It sounds as if MakeMKV doesn't have this disk's key yet, but that KEYDB does. However, I also think KEYDB has contained an entry forFu2chN wrote: Sun May 11, 2025 9:57 pm My laste keydb date is 09/05/2025
0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 = TUNNEL_TO_SUMMER (TUNNEL TO SUMMER) | D | 2025-03-11 | ...-
Fu2chN
Re: Key Add - Tunnel To Summer
Maybe US disc, I have the french disc release 07/05/2025
MrPenguin
The MakeMKV variant of DiscID=0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 is 2C04.
What is your DiscID please, i.e. the SHA1 hash of the AACS/Unit_Key_RO.inf file?
Can you attach your dump file here. We can confirm or add your disc's key if not in the keyDB database.Fu2chN wrote: Sun May 11, 2025 9:57 pm My laste keydb date is 09/05/2025
Fu2chN
Here is the dump.
I remind you that now it passes, apart from the AACS message, everything is ok.
You shouldn't get that message if everything is working correctly! Are you using the latest version (v1.18.1) of MakeMKV?Fu2chN wrote: Mon May 12, 2025 4:27 am Here is the dump.
Yes, I can confirm that the existing KeyDB entry for disc ID: 0xBF68CDFDFE7352793D0EF4540E53DD34C7159E57 is correct and is the same as Fu2chN's disc.
Fu2chN
yes I use the latest version of MakeMKV.MartyMcNuts wrote: Mon May 12, 2025 5:32 amYou shouldn't get that message if everything is working correctly! Are you using the latest version (v1.18.1) of MakeMKV?Fu2chN wrote: Mon May 12, 2025 4:27 am Here is the dump.
- Sans titre.jpg (117.98 KiB) Viewed 9187 times
