Indiana Jones and Transformers dump
Torsten
Post by Torsten » Thu May 08, 2025 9:11 am
I couldn't get these to rip and sent them, I hope it wasnt just me who was having issues.
MKB20_v61_Transformers_Age_of_Extinction_6B4B
MKB20_v61_Transformers_Dark_of_the_Moon_0A0D
MKB20_v61_Transformers_F0A9
MKB20_v61_Transformers_Revenge_of_the_Fallen_E56B
MKB20_v61_Transformers_The_Last_Knight_6BAF
MKB20_v61_Transformers_The_Last_Knight_D3FB
MKB20_v76_Indiana_Jones_and_the_Kingdom_of_the_Crystal_Skull_853D
MKB20_v76_Indiana_Jones_and_the_Last_Crusade_2C0B
MKB20_v76_Indiana_Jones_and_the_Raiders_of_the_Lost_Ark_FA0F
MKB20_v76_Indiana_Jones_and_the_Temple_of_Doom_BF1F
Please let me know if these had been done before and I just need to fix something
Re: Indiana Jones and Transformers dump
Post by dcoke22 » Thu May 08, 2025 4:07 pm
Unless people post what dumps they've submitted (and you can find them in search), it is hard to know if they've been submitted before. Submitting dumps again doesn't hurt anything.
That said, none of those are new titles and while occasionally an older title gets a new pressing with a new key, it seems unlikely that all of those discs would be in that boat.
Do you see "Automatic HK downloading is disabled or failed" in your log? If so, that would indicate that MakeMKV is unable to download hashed keys.
MrPenguin
Post by MrPenguin » Thu May 08, 2025 4:20 pm
Torsten wrote: Thu May 08, 2025 9:11 am MKB20_v61_Transformers_Age_of_Extinction_6B4B
Have you also tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
I would expect this to help with at least some of your disks, and I'm sure The Powers That KEYDB would be interested in examining the TGZ dump files of the others please.
Torsten
Post by Torsten » Fri May 09, 2025 4:12 am
I did try adding the latest keydb file, i didnt see it get consumed tho so i dont know if that worked. I didn't have a download error, I have internet access on. It just says volume key unknown.
I have gotten other 4k discs to read fine before. So Im not sure whats different.
Post by dcoke22 » Fri May 09, 2025 12:06 pm
Torsten wrote: Fri May 09, 2025 4:12 am I did try adding the latest keydb file, i didnt see it get consumed tho so i dont know if that worked. I didn't have a download error, I have internet access on. It just says volume key unknown.
If MakeMKV has worked for UHDs in the past for you it is probably still working and perhaps all of those discs need new hashed keys to unlock them. Please try posting a couple of those dumps somewhere the keydb crowd can get them (either as attachments here or a download link). They can verify if they're in the KEYDB.cfg or not and if not, they can add them.
MrPenguin
Post by MrPenguin » Fri May 09, 2025 1:22 pm
The KEYDB.cfg file isn't visibly "consumed". MakeMKV uses it as a fall-back database (assuming it's present) whenever it cannot find a key in its own "hashed keys" database. So if MakeMKV still cannot decrypt your disks, it sounds like KEYDB.cfg doesn't contain your keys either. In which case, could you provide your TGZ dump files here please, either as attachments of via download links, so that The Powers That KEYDB can examine them?
Torsten
Post by Torsten » Fri May 09, 2025 10:20 pm
heres the first few
Torsten
Post by Torsten » Fri May 09, 2025 10:21 pm
the rest of transformers box set
Torsten
Post by Torsten » Fri May 09, 2025 10:22 pm
and the rest of indiana jones
Torsten
Post by Torsten » Fri May 09, 2025 10:23 pm
Here is the other version of last knight i have as well
MrPenguin
Post by MrPenguin » Sat May 10, 2025 12:40 am
Torsten wrote: Fri May 09, 2025 10:21 pm the rest of transformers box set
Could you also provide the AACS/MKB_RO.inf file from the physical UHD disk for the 6BAF variant of "Transformers The Last Knight" disk please ? You will almost certainly need to ZIP-compress it first, because it is likely to be very big :). Unfortunately, the copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV :(.
(Feel free to provide the AACS/MKB_RO.inf file from both variants of "The Last Knight" if you cannot tell the variants apart, although we only really need the one from the 6BAF variant :).)
Torsten
Post by Torsten » Sat May 10, 2025 4:38 am
I checked and the D3FB is from the ultimate 5 moive collection box set, the 6BAF is a stand alone release. I have them both attached anyways
MrPenguin
Post by MrPenguin » Sun May 11, 2025 9:13 pm
Torsten wrote: Sat May 10, 2025 4:38 am I checked and the D3FB is from the ultimate 5 moive collection box set, the 6BAF is a stand alone release. I have them both attached anyways
Thanks, have you tried downloading the latest KEYDB.cfg file since providing this information?
Torsten
Post by Torsten » Mon May 12, 2025 3:55 am
I have last knight going right now! thank you all. I also just realized my first three didnt attach so i have them here
