Need LibreDrive patching :)
NeedLibredrive
Post by NeedLibredrive » Thu May 08, 2025 11:14 pm
Hi friends,
I’m using a Pioneer External Blu-ray Drive BDR-XD08B USB 3.2 Gen1 (USB Type-C) / 2.0 Slim Portable BD/DVD/CD Writer drive on macOS. MakeMKV shows “LibreDrive possible, not yet enabled.”
Attached’s my firmware dump file. Could you please help enable LibreDrive?
Thanks so much,
Irene
MrPenguin
Re: Need LibreDrive patching :)
Post by MrPenguin » Fri May 09, 2025 12:03 am
NeedLibredrive wrote: Thu May 08, 2025 11:14 pm I’m using a Pioneer External Blu-ray Drive BDR-XD08B USB 3.2 Gen1 (USB Type-C) / 2.0 Slim Portable BD/DVD/CD Writer drive on macOS. MakeMKV shows “LibreDrive possible, not yet enabled.”
This firmware is known. Your answer is at hand...
All I can say now is "Patience, Grasshopper!" :)
NeedLibredrive
Post by NeedLibredrive » Fri May 09, 2025 12:37 am
Hi Mr Penguin thanks for the reply--I've gone to that page but it's all to technical for me, just a casual user. Does this message mean I'll get a DM with a Libredrive patch or that there is no patch avail yet? Thank you :)
Post by Billycar11 » Fri May 09, 2025 12:52 am
NeedLibredrive wrote: Fri May 09, 2025 12:37 am Hi Mr Penguin thanks for the reply--I've gone to that page but it's all to technical for me, just a casual user. Does this message mean I'll get a DM with a Libredrive patch or that there is no patch avail yet? Thank you :)
you wont get a DM but you will have to flash the drive yourself or im sure me and Marty will have auto flash kits out soon after release
