Dump file?
natra
Dump file?
How long time does it take before makeMKV decrypts the dump file.
MrPenguin
Re: Dump file?
The only answer to that is "as long as it takes". But if you have a dump file then you could try sharing it here so that The Powers That KEYDB can try to help you too.natra wrote: Thu May 08, 2025 10:19 am How long time does it take before makeMKV decrypts the dump file.
MrPenguin
Re: Dump file?
Thanks for this. Could you also provide a ZIP file containing the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, making it unusable by anyone except MakeMKV itself
natra
MrPenguin
Re: Dump file?
Thanks, but that link takes me to my own Google Drive instead of yours
To be fair, you could probably upload the ZIP file here as an attachment.
natra
MrPenguin
Re: Dump file?
Thanks, but can you also provide the AACS/MKB_RO.inf file from your UHD disk please? You will almost certainly need to zip-compress it, as it will be very big.
MrPenguin
Re: Dump file?
Thanks, we do need this file, but you have already provided it. All we need now is the AACS/MKB_RO.inf file from your physical UHD disk, as this will provide an extra piece of information which is missing from your TGZ dump file.
MrPenguin
Re: Dump file?
It's on the UHD disk. Put your disk in your UHD drive, wait for MacOS to mount it, and then look in its AACS/ directory. We need the MKB_RO.inf file.
natra
MrPenguin
Re: Dump file?
Thanks, this shall be offered up to The Powers That KEYDB...
MrPenguin
Re: Dump file?
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV? I would hope that would work now, but if not then hopefully it will tomorrow.
