speed
flacon030
speed
Post by flacon030 » Mon May 05, 2025 3:58 pm
OS device name: /dev/rdisk5
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: ...
Firmware date: 2117-04-25 17:56
Highest AACS version: 76
Firmware version: 1.00
Disc Information
Label: SPEED
Timestamp: 2021-03-16 10:25:50
Protection: AACS2.0/C v76
Data capacity: 59.64 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
Evaluation version, 23 day(s) out of 30 remaining
Saved AACS dump file as /Users/flacon030/Movies/DVD Ripper/MKB20_v76_Speed_407B.tgz
MrPenguin
Re: speed
Post by MrPenguin » Mon May 05, 2025 9:22 pm
flacon030 wrote: Mon May 05, 2025 3:58 pm Saved AACS dump file as /Users/flacon030/Movies/DVD Ripper/MKB20_v76_Speed_407B.tgz
flacon030
Re: speed
Post by flacon030 » Tue May 06, 2025 3:49 pm
Merci cela fonctionne, désolé pour le dérangement
Thank you it works, sorry for the inconvenience
