Dump submitted - Scoob! Variant (6FB1)
ManagedMoTion
Post by ManagedMoTion »
Hello must be a variant of Scoob.
I've updated my keydb.cfg file with the latest from May 5,2025
Yes I've tried restarting MakeMKV.
I've zipped the TGZ and MKB_RO file.
MrPenguin
Re: Dump submitted - Scoob! Variant (6FB1)
Post by MrPenguin »
ManagedMoTion wrote: Mon May 05, 2025 9:01 pm I've updated my keydb.cfg file with the latest from May 5,2025
This all looks good :)! Have you also installed SamuriHL's KEYDB Helper tool? This has a useful "validate disc" option.
Edit: This disk appears to have a partial entry in KEYDB already, although its Unit Key doesn't look right to me :cry:.
keydb_helper
Post by keydb_helper »
ManagedMoTion wrote: Mon May 05, 2025 9:01 pm Hello must be a variant of Scoob.
Thank you for providing a suitable dump file. The 6FB1 variant of Scoob! has been added to the public keydb.
MrPenguin wrote: Mon May 05, 2025 9:32 pm This all looks good :)! Have you also installed SamuriHL's KEYDB Helper tool? This has a useful "validate disc" option.
The unit key which starts with 0xFA23 is incorrect.
Submitting a complete keydb entry does not override the existing unit key but the correct unit key can be derived with the newly added VUK. The correct unit key starts with 0x15E5...
I'm not sure why the unit key for Donovan's Reef was paired with this particular disc.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
MrPenguin
Post by MrPenguin »
Could you try using SamuriHL's KeyDB Helper tool to validate your disk against the new KEYDB entry please? I am hoping that this will fix the entry's incorrect Unit Key value.
