Archgon MD-8107-U3 Linux Issues
Civil9808
Post by Civil9808 » Mon May 05, 2025 12:15 am
Hello, I have encountered several, likely related, issues trying to get the Archgon MD-8107-U3 working right on my Linux machine. My primary machine is a Nobara Linux machine (Fedora derivative), but I have access to an Ubuntu system where most of this was done. If you only care about the biggest issue please skip to #3.
1) Flashing does not work on MakeMKV 1.18.1
I was able to flash on my Ubuntu system fine, but only on version 1.17.7. 1.18.1 would hang whenever I would initiate flashing
2) After flashing to HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 - found in the everything firmware zip file on the UHD drive help post - the drive was no longer visible to my Fedora system running the Flatpak of MakeMKV. The error was "The program can't find any usable optical drives.", yet the drive would appear in my system without problems
There's a good chance that something went amiss as I was trying to get MakeMKV installed natively instead of through Flatpak so I could flash the drive, but if anybody has insights here I'd appreciate it.
3) The biggest issue, the flashed version of the drive still will not read UHD blurays.
Here's the full dump of info:
**Drive Information**
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: ...
Highest AACS version: 77
Firmware version: 1.03
**Error Message**
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as /home/user/.MakeMKV/MKB20_v77_ARCANE_SEASON_1_-_DISC_1_3953.tgz
The previous version of the drive was 1.02, I believe, and it produced this same error. The flashing process was also error-free.
I tried on two different Blurays (Arcane's and Ghost in the Shell's UHD US releases) and neither worked, which is likely not related to needing to post the dumps. I can make those available if that's needed.
Any help would be greatly appreciated :). Thank you!
Re: Archgon MD-8107-U3 Linux Issues
Post by MartyMcNuts » Mon May 05, 2025 4:44 am
Civil9808 wrote: Mon May 05, 2025 12:15 am Hello, I have encountered several, likely related, issues trying to get the Archgon MD-8107-U3 working right on my Linux machine. My primary machine is a Nobara Linux machine (Fedora derivative), but I have access to an Ubuntu system where most of this was done. If you only care about the biggest issue please skip to #3.
Revision: 1.03
Serial number: ...
**Error Message**
Once flashed with BU40N 1.03-MK, flash again to BU40N 1.00. This is the best firmware to use on Linux.
Civil9808
Post by Civil9808 » Mon May 05, 2025 6:22 am
@Marty
MartyMcNuts wrote: Mon May 05, 2025 4:44 am Once flashed with BU40N 1.03-MK, flash again to BU40N 1.00. This is the best firmware to use on Linux.
Hi Marty, thanks for your response. I gave this a try and I have a different error. Here's what I've got:
I found the firmware in the Downgrade Enabled Firmware V.2 zip file.
New firmware information on the drive:
Revision: 1.00
Serial number: ...
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
I am now getting the same error for both Ghost in the Shell (GITS) and Arcane - "The volume key is unknown for this disc - video can't be decrypted"
I have attached the GITS AACS dump file, just in case the key has, indeed, not been generated. Please let me know if that's the case, or if there's still an issue with the drive. Additionally, if I grabbed the incorrect firmware, please provide a link to the correct firmware.
Post by MartyMcNuts » Tue May 06, 2025 12:00 am
Civil9808 wrote: Mon May 05, 2025 6:22 am @Marty
Revision: 1.00
Serial number: ...
Have you made sure MakeMKV has internet access? It is needed so the UHD hasheed keys can be downloaded as needed.
Have you noticed anything in the log stating HK download failed or is disabled?
Civil9808
Post by Civil9808 » Tue May 06, 2025 10:24 pm
MartyMcNuts wrote: Tue May 06, 2025 12:00 am Have you made sure MakeMKV has internet access? It is needed so the UHD hasheed keys can be downloaded as needed.
The host OS has internet access for sure, I'm not sure why MakeMKV wouldn't. I also have not noticed anything in the logs suggesting the HK download failed. Is there a way to check this affirmatively, like a text file hiding in a directory I can look for or a command I can run to be sure?
Thanks again for the help, Marty
Post by dcoke22 » Tue May 06, 2025 11:44 pm
Civil9808 wrote: Tue May 06, 2025 10:24 pm The host OS has internet access for sure, I'm not sure why MakeMKV wouldn't. I also have not noticed anything in the logs suggesting the HK download failed. Is there a way to check this affirmatively, like a text file hiding in a directory I can look for or a command I can run to be sure?
On the General tab of MakeMKV's preferences, make sure the checkbox for 'Enable Internet access' is checked.
Civil9808
Post by Civil9808 » Wed May 07, 2025 1:04 am
dcoke22 wrote: Tue May 06, 2025 11:44 pm On the General tab of MakeMKV's preferences, make sure the checkbox for 'Enable Internet access' is checked.
I verified that was checked, and I also noticed booting up this time that the software downloaded the latest sdf.bin without reporting any issues. What would be the next thing to check?
Thanks again
MrPenguin
Post by MrPenguin » Wed May 07, 2025 10:42 am
Civil9808 wrote: Wed May 07, 2025 1:04 am I verified that was checked, and I also noticed booting up this time that the software downloaded the latest sdf.bin without reporting any issues. What would be the next thing to check?
I'm fairly sure that MakeMKV already knows your disk's decryption key. MakeMKV's "hashed keys" database should have been downloaded into this file:
$HOME/.MakeMKV/_private_data.tar
so it might be worth checking this file exists on your machine. (It's about 9MB on mine.)
Have you tried downloading the public KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. $HOME/.MakeMKV in your case) and restarting MakeMKV? MakeMKV can use KEYDB as a fallback database, if available, should it not find your key in the "hashed keys" database.
Civil9808
Post by Civil9808 » Fri May 09, 2025 8:07 pm
MrPenguin wrote: Wed May 07, 2025 10:42 am I'm fairly sure that MakeMKV already knows your disk's decryption key. MakeMKV's "hashed keys" database should have been downloaded into this file:
Gave this a try, here's the outcomes:
1) I looked for the MakeMKV` _private_data.tar` and, indeed, that does exist on my machine. That file seems to be insufficient to read the UHD blurays I was using.
2) I grabbed the public KEYDB.cfg and that, *did* work; I tried that on the few UHD blurays I have lying around and it was able to read all of them.
So for my part for now it looks like I'm covered, so thank you everybody for the help!
That said, I also am curious if there's anything more I can understand from this, anybody have any ideas about why the MakeMKV hashed key database didn't work? Is that the sort of situation where I send the dump in to get it added to MakeMKV's database? Thoughts here are appreciated :D. Thanks again
MrPenguin
Post by MrPenguin » Fri May 09, 2025 11:03 pm
Civil9808 wrote: Fri May 09, 2025 8:07 pm That said, I also am curious if there's anything more I can understand from this, anybody have any ideas about why the MakeMKV hashed key database didn't work? Is that the sort of situation where I send the dump in to get it added to MakeMKV's database? Thoughts here are appreciated :D. Thanks again
If MakeMKV cannot decrypt a disk then it will generate a TGZ dump file. You should email such dump files to svq@makemkv.com so that MakeMKV can add you disk into its "hashed keys" database. However, you can also make such TGZ dump files available to The Powers That KEYDB, so that your disk may (no guarantees) also be included in the KEYDB.cfg file.
Civil9808
Post by Civil9808 » Fri May 09, 2025 11:42 pm
MrPenguin wrote: Fri May 09, 2025 11:03 pm
Great! Can do. Thanks again for the help :D
