How to find dump for failed 4k Tombstone rip
viper1171
#1 Post by viper1171 » Tue Apr 29, 2025 5:49 am
How do I find the dump and where do I upload data for new Tombstone 4k U.S. release 2025 failed rip.
Re: How to find dump for failed 4k Tombstone rip
#2 Post by dcoke22 » Sat May 03, 2025 1:38 pm
When MakeMKV produces a dump file, it lists where it creates the file in the log section on the bottom of the screen.
UHD FAQ
viper1171
#3 Post by viper1171 » Sun May 04, 2025 3:48 am
I already closed the program 3 days ago when Tombstone 4k U.S. release failed to rip. I didn't want to spend almost an hour to produce another dump file location & thought I just could be told where the location is SMH.
#4 Post by dcoke22 » Sun May 04, 2025 2:21 pm
MakeMKV produces a dump file when it can't decrypt a disc. This happens at the beginning of a rip. If you're experiencing a failure after it has been ripping for an hour, it isn't a decryption failure that will produce a dump.
I would even speculate that the suggestion for the rip failure would be to gently clean the disc and try again, even if the disc is brand new.
MrPenguin
#5 Post by MrPenguin » Sun May 04, 2025 2:23 pm
viper1171 wrote: Sun May 04, 2025 3:48 am I already closed the program 3 days ago when Tombstone 4k U.S. release failed to rip. I didn't want to spend almost an hour to produce another dump file location & thought I just could be told where the location is SMH.
You don't need to produce another dump .Just start MakeMKV, go to its "View/Preferences/General" tab, and look at its "data directory" field.
viper1171
#6 Post by viper1171 » Mon May 05, 2025 6:05 am
Thank you MrPenguin for being so kind as to direct me to the dump file location, I appreciate it. So as to my Tombstone 4k U.S. version progress update. I have cleaned the disk approx. 23 times and had given up to be honest. One last time I buffed the @#$% out of the disk creating heat & even slightly bending it as I pressed and cleaned it with a cleaner solution that I have. Tossed it one final time into my drive and holy #%$@ it passed the area it couldn't read and completed the rip! I am so happy and grateful to those that were helpful to me.
